Author Topic: Early Sandcast Found......  (Read 101270 times)
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: Early Sandcast Found......
« Reply #950 on: June 01, 2023, 01:27:23 PM »
Not heard of Simichrome, I wonder how it compares with Solvol Autosol
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #951 on: June 01, 2023, 02:12:01 PM »
I’ve been aware of it for decades, just have not used it. I hear it’s good stuff.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #952 on: June 09, 2023, 12:16:03 PM »
Cool and rainy today, so I went down to the shop and cleaned up. Rushing to prep the K1 and the K3 for the Ganaraska 250 left a bit of a “trail” in there…….
Decided to do a bit more on the top end of the s/c motor. Cam towers and cam are in, making sure all the marks are in the right places. Rockers and shafts next time. New “pucks” got a very thin ring of “Hondabond”. Lots of lube on the cam bearing surfaces and two drops of Locktite on the cam gear locating screws. Everything pulled down nicely, no helicoils so far!
« Last Edit: June 11, 2023, 05:58:10 PM by BenelliSEI »
« Reply #953 on: June 09, 2023, 03:07:50 PM »
Nice, slow and steady wins this race
Offline BenelliSEI
  • 1969 cb750
« Reply #954 on: June 09, 2023, 04:07:50 PM »
Absolutely. More hours riding/ less in the shop!
After this project, I need to finish the Rickman CR and I have a very nice K6 waiting for a good clean up and fresh engine. No rush, at all.
Offline BenelliSEI
  • 1969 cb750
« Reply #955 on: June 11, 2023, 12:34:58 PM »
Finished up the top end today. All pulled down nicely, and valve clearances are done too. So much easier with the cam cover off!
« Last Edit: June 12, 2023, 10:56:14 AM by BenelliSEI »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #956 on: June 12, 2023, 07:56:10 AM »
Will you be painting the engine?
1973 CB 750 K3
Offline BenelliSEI
  • 1969 cb750
« Reply #957 on: June 12, 2023, 10:55:24 AM »
Steve…….. will be painting it. Started the painful process of final cleaning everything and then masking up “spare” covers today. Then the motor has to come out of the stand, so I can paint the “arse end”. I then put it back in the stand, flip it upside down and do all the paint from the bottom. Flip it up and paint everything again, from the top.
As I keep saying, not in a rush. Determined to do other stuff instead. We are also heading off to Calabogie next weekend, for another double header. 2 X 8 hour races in the Lexus, coming up!
« Last Edit: June 12, 2023, 11:01:03 AM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #958 on: June 12, 2023, 11:29:40 AM »
This is the paint I use here. Seems some people are using something with “ceramic” added? Curious to know more.
« Reply #959 on: June 12, 2023, 12:17:31 PM »
Hi John...yes, the Dupli-Color paint I use is "enamel with ceramic", color is Aluminum DE 1615
https://www.oreillyauto.com/detail/c/engine-enamel-with-ceramic/dupli-color-12-ounce-aluminum-spray-paint/dplg/de1615
"Dupli-Color Engine Enamel contains Ceramic Resins for maximum heat dissipation and gloss retention"
I believe ceramic is best for high heat applications. I'm going to have the GTO's exhaust manifolds ceramic coated as opposed to powder coating so the coating will hold up.
« Reply #960 on: June 12, 2023, 12:20:41 PM »
Ask Mark, HondaMan, I think he just used the Duplicolor ceramic formula on the K0 he is rebuilding. Even if he didn’t, he would know about it…he’s just that way. Given his side gig is rebuilding lots of motors over the past couple years he likely has used the ceramic before if he isn’t currently using it.
Offline BenelliSEI
  • 1969 cb750
« Reply #961 on: June 12, 2023, 12:28:11 PM »
Thanks guys! I’m not sure it’s available in Canada, but I will look before I use up the “regular” ones I have……
Offline grcamna2
« Reply #962 on: June 12, 2023, 02:44:30 PM »
The can in the pic you've uploaded here John:does that have metallic in the finish ?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #963 on: June 12, 2023, 02:49:34 PM »
I’m not sure what the ceramic is in the paint, I’ve used it, seems like a good product.
1973 CB 750 K3
Offline lash
« Reply #964 on: June 12, 2023, 03:14:26 PM »
John, Napa Canada has it.
Offline BenelliSEI
  • 1969 cb750
« Reply #965 on: June 12, 2023, 03:54:16 PM »
No metallic, or ceramic. It is +two years old, probably +3…..
« Last Edit: June 12, 2023, 05:24:02 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #966 on: June 12, 2023, 05:24:45 PM »
Thanks, I’ll try it.
Offline BenelliSEI
  • 1969 cb750
« Reply #967 on: June 22, 2023, 09:04:36 AM »
Yamiya finally showed the “red foam” seat kits back in stock. Stupid money plus $140 shipping! But, I really want to restore my original seat, so pulled the trigger. Ouch.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #968 on: June 22, 2023, 02:47:41 PM »
Shipping here to Maui can be as high as the price of the item.
We just have to grit our teeth.
1973 CB 750 K3
Offline BenelliSEI
  • 1969 cb750
« Reply #969 on: June 22, 2023, 04:20:07 PM »
So true! I’m not that deep into this one, although it’s staggering how fast the spend is moving along. I swore I was not going to restore another one, after the K0 “show bike”, but I’m actually enjoying the leisurely pace on this one!
Offline BenelliSEI
  • 1969 cb750
« Reply #970 on: June 28, 2023, 04:41:08 PM »
UPS promised delivery of my “red foam” today, followed up by another invoice for $69 for tax, duty, brokerage etc.! I paid it and at 7:40pm still no show…….
Offline BenelliSEI
  • 1969 cb750
« Reply #971 on: June 29, 2023, 01:38:13 PM »
Rescheduled until next Tuesday! Fingers crossed.
Yamiya is out of stock again!
« Last Edit: June 30, 2023, 05:25:15 AM by BenelliSEI »
Offline Prospect
« Reply #972 on: June 30, 2023, 01:14:40 PM »
Such great work John! Your attention to detail and patience is truely inspiring. I try and take a page from your book and slow down when I work on my bikes.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #973 on: June 30, 2023, 07:22:21 PM »
We all are looking forward to the finished bike but we aren’t rushing you
1973 CB 750 K3
« Reply #974 on: June 30, 2023, 07:44:24 PM »
He and his racing buddies have a motor swap to do in less than a month on the Lexus, so I would not expect much movement on bike projects for a beat…
