Author Topic: Any experience with a 550 Nighthawk  (Read 910 times)
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« on: February 06, 2021, 06:29:13 PM »
One of my moles called and wanted to know if I am interested in a 550 Nighthawk. He works for a local utility and gets into a lot of places. Said appears to be in decent shape and they want it out of the garage. Any thoughts of value and what to look for?
Fonda Honda
Offline grcamna2
Re: Any experience with a 550 Nighthawk
« Reply #1 on: February 06, 2021, 08:07:18 PM »
I believe that was only a '1 year bike',those are bulletproof when running.I would love to have one myself.
« Reply #2 on: February 07, 2021, 05:51:00 AM »
 A friend of mine who lived a ways away had one once that he would of gave me but I passed. He got it somehow and claimed it needed a starter and claimed he could not find one anywhere. Never really looked into it but thought maybe parts may be hard to find ??
Offline rb550four
« Reply #3 on: March 21, 2021, 04:40:53 PM »
  I have one, picked it up cheap. the owner had taken some it apart breaking every bolt on the top cover. Don't know what he did once he opened it up but when I got it running it sounded like a lifter needed to be bled and refilled . I took it for a few rides, they are much quicker than our sohc and the same engine with different bores and strokes were used in other nighthawks so there are parts out there.
A few years before picking up this 81' 550 ,I picked up an 83' 650 , both engines are the same size and configuration so the 650 is a direct fit into the 550 frame except for the air box, so when I swap motors into the lighter ,smaller 550 frame , the airbox to carb boots will be swapped from the 650 to the 550 airbox completing the direct swap using the larger carbs that came with the 650 engine.  Both frames are not interchangeable ,only the engine cradle is , the 650 is a heavier/stronger frame and the drivetrain and brakes are also larger. The 650 it's been said has different ( better ) gear ratios with a real overdrive . the 55o overdrive wasn't much overdrive and felt like you were actually loosing speed after shifting to overdrive. Can't tell you if the 650 engine will chew up the drive on the 550 ,but when it's finished I should be able to report on that.....whenever I get it finished. Oh , I put 3 inch rise bars on the 550 for the test drives, so much better, threw out those stock 550 bars.
Offline grcamna2
« Reply #4 on: March 21, 2021, 04:44:48 PM »
Wasn't the 550 chain drive? I know the 650's are shaft.
Offline Alan F.
« Reply #5 on: March 21, 2021, 04:52:34 PM »
I think the 550 is shaft too, that's why I never tried swapping those cool wheels onto my k3.
Offline rb550four
« Reply #6 on: March 22, 2021, 03:38:41 PM »
 Yes , the 550 is a shaft drive  but the rear hub  is smaller than the 650's rear hub and at this time I don't know if they will switch easily. I'll try that and see if it works , if it doesn't I'll see if the swing arms can be swapped so I can use the heavier brakes and stronger drive since the 550 should be a little faster with the 650 engine . I would like to have the proper amount of braking for the upgrade in power.
