Author Topic: Identification of points cover  (Read 801 times)
Offline Peter327
« on: February 06, 2021, 08:11:31 PM »
Hi guys,
My CB500 four K0 project bike has a points cover that is not like any I have seen elsewhere.
And it is nothing like what I see on parts diagrams.
Can anyone explain this please?
Peter.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Identification of points cover
« Reply #1 on: February 06, 2021, 08:26:11 PM »
It’s an aftermarket piece.  I have these under my bed.
« Reply #2 on: February 06, 2021, 10:13:26 PM »
Do all cb500/4 have 3 screw points cover?...just curious as all the 550/750's have 2 screws and I have not worked on a cb500 before.
Offline Peter327
« Reply #3 on: February 06, 2021, 10:34:54 PM »
Seanbarney41..............from what I have seen they have 2 screws.  That's why I'm confused with my bike, which has 3 screws.
And Medyo Bastos,............. looks like you have a points cover on the right hand side in your photo, which only has 2 screw holes.  But even that's odd as from what I've seen the engine casing holes are almost horizontal, which would make your 'SOHC' on an angle  pointed towards 1 o'clock.
Also an aftermarket product wouldn't be allowed to produce a product with 'HONDA' on it.
« Reply #4 on: February 06, 2021, 11:44:57 PM »
It's off a Honda 350 twin , other side of motor.
 And if not that then the 450..
 And while you can not produce a cover today that says Honda.... legally..
 20 or more years ago many people were doing it  for a long time..
« Reply #5 on: February 07, 2021, 12:22:01 AM »
ok...so the 2 hole orientation...cb750 has holes exactly 12 o'clock and 6 o'clock cb550 has 'em more diagonal, I assumed the 500 was the same but don't really know
Peter, have you had that cover off yet?
« Reply #6 on: February 07, 2021, 08:44:50 AM »
500 has 2 holes but not at 12 and 6 o'clock like the 750.
 So this must have an adaptor in between..
Offline Peter327
« Reply #7 on: February 07, 2021, 12:20:27 PM »
Thanks guys.
I'll look at the 350 / 450 diagrams.
SeanBarney41, no, haven't had the cover off yet.  Screws have been done up by a gorilla.  Have WD-40 on them at moment.
« Reply #8 on: February 07, 2021, 04:50:08 PM »
That cover has  to be bigger than the case behind it.  What else is on that motor ?
 If you can't get them out drill them.
Offline Peter327
« Reply #9 on: February 12, 2021, 07:59:55 PM »
Bought an impact driver to get that cover off and yes there is an adaptor plate behind it.
And yes the cover is slightly larger in diameter.  The adaptor plate tapers down to the true engine case size.
« Reply #10 on: February 16, 2021, 07:44:13 AM »
My [early] CB450 has a 3 hole points cover but the top hole is not at "12:00"
