Author Topic: Oil Cooler Suggestions for SOHC CB750  (Read 4022 times)
Re: Oil Cooler Suggestions for SOHC CB750
« Reply #25 on: February 17, 2021, 05:53:13 PM »
 Here is 3 major sizes , types of Lockhart,  there is also built in Thermostat  ones.
 The mid size  came in black or chrome and is most common.
 The narrow one I have seen in a Vertical configuration,  I think for Sportsters. Likely with hose barbs.
 The threaded port I prefer if you want to run real braided lines.. not the hose clamp type.
« Last Edit: February 17, 2021, 05:56:26 PM by 754 »
Online PeWe
« Reply #26 on: February 19, 2021, 11:44:34 PM »
Perfect with a complete kit, just bolt on.
I had thoughts about an oil cooler on my K6.
Purchased a Setrab cooler but did not collect all parts to complete.
I would like to use a thermostat that open after 100C.
I believe that oil must be hot enough to let condense water out.
Cooler to avoid 120C that a good oil can handle, but shorten life.
