Author Topic: Stator neutral switch  (Read 936 times)
Offline JWB
« on: February 08, 2021, 04:40:39 PM »
74 550
Is this neutral switch ok to use, or is there something missing for the contact point?
Question about installation: Should the switch be closed(contacts touching) when the motorcycle is in neutral?
Re: Stator neutral switch
« Reply #1 on: February 08, 2021, 04:57:27 PM »
Thats just the static part and looks ok there is rotor on the selector drum which has acopper contact on it thatouches the contact finger when in neutral making a ground path
Offline JWB
« Reply #2 on: February 08, 2021, 05:52:47 PM »
Thanks Bryan,
With your information I cleaned up the rotor and now I see how it works.  It was solid black before I cleaned it so couldn't figure out how the connection would be made.  Now it all makes sense.
« Reply #3 on: February 09, 2021, 01:16:51 AM »
Should be a "pip" on the back that locates in a notch on the druk
Offline JWB
« Reply #4 on: February 09, 2021, 06:43:32 AM »
A bit of the pip remains, hope it is enough to keep it in alignment.
« Reply #5 on: February 09, 2021, 12:18:59 PM »
Do it up carefully and check it out, i do have some nos rotors but i paid a lot for them and i am in UK and just recently postage has gone crazy
Offline JWB
« Reply #6 on: February 09, 2021, 04:55:55 PM »
Thanks, if it doesn't work I may take you up on your offer.
