Author Topic: CB400F turn signal relay  (Read 651 times)
Offline Claude
« on: February 10, 2021, 05:24:38 PM »
I'm restoring a 1977 CB400F.
Turn signals works correctly (maybe a bit slowly but probably acceptable).
All bulbs are STD incandescent.
On wiring diagram, there are three wires that goes to the relay and there's also three wires on my bike.
However, the turn relay only has two pins so one of the wires is not used.
QUESTION
Is my bike OEM of does it need a 3 pin turn signal relay?
Thanks!
Offline Flyin900
Re: CB400F turn signal relay
« Reply #1 on: February 10, 2021, 05:55:35 PM »
Usually the one wire is a green that is not used on the two pin relay. The grey and black are the two other colours from what I recall. The slow flash could be a combination of oxidized contacts at the signal bullet connectors. It is best to go through all the ground points on the signals to the chassis and clean up all the bullet connectors too. These bikes at idle don't charge or put out a strong voltage, so it maybe related to your entire system being aged and cleaning the contact and connectors may help you there.
Your flasher could be tired too as they rely on a simple heat to break contact system inside the flasher box, if it is still the original one on there.
« Last Edit: February 10, 2021, 05:57:45 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #2 on: February 10, 2021, 11:42:11 PM »
3 pin relay required in some countries like UK , speed will get quiker when engine running and battery charging
Offline Claude
« Reply #3 on: February 11, 2021, 07:59:25 AM »
Thanks guys!!
