Author Topic: Reusing float bowl gaskets  (Read 2108 times)
Re: Reusing float bowl gaskets
« Reply #25 on: February 28, 2021, 04:19:27 PM »
You could try grinding or filing it off...but it is so tiny.  Any time i have dealt with it, i just unscrew the nut, hoping it will cleanly cut new threads, and it mostly always has worked.  You just have to be careful to get the tiny nuts started straight when you put them back.  That, or do as Ekpent, and dont mess with them.
Offline BenelliSEI
  • 1969 cb750
« Reply #26 on: February 28, 2021, 05:45:50 PM »
Seanbarney-
Was there a way to remove the nut without harming the staking?
Appreciate the insight BenelliSEI and BryanJ!
Not really..... bit of a crap shoot.
Offline The Gurg
« Reply #27 on: March 01, 2021, 07:47:38 AM »
Got the nylock nuts and they sit too proud (see photo). Guess I’ll be using pfte tape or loctite.
Offline BenelliSEI
  • 1969 cb750
« Reply #28 on: March 01, 2021, 08:44:46 AM »
Omit the lock washer, not required with nylock. And add a small drop of blue loctite. It won’t move. I also find you can’t really snug those nuts down, or the lever gets jammed. That’s why they never really tighten the nut and had to stake them....
Offline StockRider
  • Sustaining SOHC/4
  • Well, I thought it was stock...
« Reply #29 on: March 01, 2021, 02:11:37 PM »
I tightened mine down first, gently cleared the staking with a Dremel bit, and backed the nuts off gently. I plan to re-stake them once I have settled on final choke linkage adjustments and whether or not to do anything about the corrosion on choke levers #3 & #4. Also, I'm waiting on a kit of stainless cotter pins from Amazon in order to replace the little ~1mm ones on the linkage.
'70 CB750K0 - "Truck" | 4x4 | 4 Cables/4 Carbs/4 Cyls/4 Pipes | PO: "Old J.O.", a.k.a. Dad, Ride Free Brother!
Offline StockRider
  • Sustaining SOHC/4
« Reply #30 on: March 01, 2021, 02:47:30 PM »
The JIS head on this choke throw from the fourth carb fell off when I took off the nut. Took the top turn of threads with it on one side. Can’t find just the throw by itself on eBay. Thinking I’ll put some loctite on it and use it. Thoughts?
Photo with carb in the picture is before the nut was removed.
Regarding replacement levers, I was tempted by the selection at Yamiya. They have zinc and chrome plated available:
https://www.yamiya750.com/index.php?main_page=index&cPath=246_21_181_143&sort=20a&page=3
I've decided today that I am going to remove as much corrosion as I can from mine, clear coat them, and move on. I prefer to keep the originals, even without re-plating. There is so much character in the way that these were soldered/brazed together and finished..., shows the character of the times.
Offline BenelliSEI
  • 1969 cb750
« Reply #31 on: March 01, 2021, 05:54:59 PM »
Nice work on the carbs! I agree, keep your original. They look great!
« Reply #32 on: March 03, 2021, 06:11:21 PM »
I've probably got some of these, or at least one.
Is it the choke lever from #4?
