Author Topic: valve cover/tappet cover/rocker cover o ring  (Read 473 times)
Offline Register
« on: February 21, 2021, 01:37:44 PM »
hi, does anyone have an idiot proof method for fitting the rocker cover o ring without inverting the engine?
I've yet to do anything other than test run and have oil seeping from under the cover.
I guess I trapped the o ring outside the channel
Thanks
Offline Kevnz
Re: valve cover/tappet cover/rocker cover o ring
« Reply #1 on: February 21, 2021, 01:59:04 PM »
Tried sticking it in with some grease?
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline DaveBarbier
« Reply #2 on: February 21, 2021, 11:15:42 PM »
If the gasket groove is totally clean, an OEM Honda gasket will hold itself in the little casting detents in the groove. You could use a bit of grease or even a couple tiny tiny dabs of super glue.
I wet the gasket with oil before install so the super glue method wouldn’t work. But really, a properly fitting gasket will hold itself if the groove is clean. I’ve never had any issues with these.
Offline Register
« Reply #3 on: February 22, 2021, 12:12:39 AM »
Thanks both for the suggestions.
I was super careful with the cleaning but have a leak in front of No.4 which runs across the head whilst on the side stand.
Drips nicely onto the alternator cover.
I'll give the suggestions a try.
Thanks
