Hi guys,
My charging system all of sudden died on me. I've gone through the diagnostic steps on the forum, and here are my results so far:
0.5 oms (after accounting for probe resistance) on all combinations of the stator wires coming out of the stator.
No continuity BTW yellow wires and ground.
Same test with same results performed on the bullet connectors behind the shifter cover.
Field coil measured at 7 oms (7.2 before accounting for resistance on probes) BTW green and white wires coming out of the stator
Battery fully charged - when switch is off 12.8v (was 13+ before I started tinkering), switch on 12.35v (headlight on)
Engine at idle: 12.35v
2k,3k,5k rpm =12.35v (no signs of charging)
AC output test (headlight on) ~60v on all three yellow wires
Took a look at the stator and rotor, didn't see any noticeable damage, melting, broken magnets, etc...
So I'm thinking r/r or a wiring issue.
As for r/r, it's a ss Rick's r/r combo unit and it fails the reverse diode test (I'm getting a consistent reading on all three yellows, but no beep). This would seem to indicate a bad r/r but its got less than 30 miles on it, so even if it is a dud, I want to be sure I'm covering the issue and not just the symptom.
One last thing, alternator is magnetizing when switch is on...
So before ordering a new unit, is there anything else I can test to be sure about thr r/r (as the symptom or the source of my charging problem)?
Thanks!
J
