Author Topic: 10mm Hanger bolt spec?  (Read 724 times)
Offline The Gurg
« on: February 25, 2021, 10:28:43 AM »
Cb750 K5
Engine hanger bolts on the torque spec sheet is for the 12mm. I think it would be to much torque for the two 10mm hanger bolts. The ones that are long. Anyone know what they should be?
Offline The Gurg
Re: 10mm Hanger bolt spec?
« Reply #1 on: February 28, 2021, 08:52:26 AM »
Bueller?...bueller? Anyone? Bueller?
Offline newday777
« Reply #2 on: February 28, 2021, 09:39:58 AM »
Stu
My current rides
Prior bikes....
Offline The Gurg
« Reply #3 on: February 28, 2021, 01:49:56 PM »
I have Hondamans comment in that post saved to favorites in photos and use it regularly. Along with torque sheets from a couple different manual iterations. So good suggestion!
I think the engine bolts in Hondamans comments are case bolts in this instance and not hanger bolts, but I could be wrong.
I torqued the two 10mm longer hanger bolts to 25ft lbs and the 12mm hanger bolt to 45ft lbs. hoping someone will correct me if I should take those 10mm up more.
« Last Edit: February 28, 2021, 01:53:16 PM by The Gurg »
Offline 69cb750
« Reply #4 on: February 28, 2021, 01:52:31 PM »
25ft lbs and the 12mm hanger bolt to 45ft lbs is fine.
Offline The Gurg
« Reply #5 on: February 28, 2021, 01:56:35 PM »
Ok awesome. Thanks guys!
