Author Topic: Setting points - extremely weird problem  (Read 8192 times)
Offline jakec
« on: March 01, 2021, 06:54:03 PM »
Setting points on stock cb550. Rebuilt points advance. New battery. All wiring connections good and clean. All spark plugs new. All wires trimmed and boots reseated. Original coils and points. Go to set timing.
Plug 3 only fires on F1.4. Plug 4 only fires on F2.3
All wiring is correct. Swap blue & yellow wire connections so now it’s “wrong.”
Plug 3 only fires on F2.3 Plug 4 STILL only fires on F2.3.
I can see the F1.4 opening. I also don’t have the points upside down or anything.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline BenelliSEI
  • 1969 cb750
Re: Setting points - extremely weird problem
« Reply #1 on: March 01, 2021, 07:50:00 PM »
Does one coil have HT leads to #1 and #4? The other coils to #2 and #3? You sure?
Offline jakec
« Reply #2 on: March 01, 2021, 07:57:04 PM »
Yes definitely confirmed that.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
  • I'm back
« Reply #3 on: March 01, 2021, 10:42:15 PM »
Did you have the advancer apart and was it reassembled incorrectly? What state is battery in? When in doubt recharge. Cancel headlamp-always-on-arrangement. What plugs and plugcaps? Are the latter firmly screwed on?
CB500K2-ED Excel black
« Reply #4 on: March 02, 2021, 01:02:23 AM »
if youve taken the assembly apart be sure its been put back correctly
Offline Alan F.
« Reply #5 on: March 02, 2021, 06:47:13 AM »
Locator pin from advanced to crank is present? They do come loose and go missing.
I know it's kinda obvious but strange symptoms sometimes need simple logic checks.
Offline jakec
« Reply #6 on: March 02, 2021, 09:09:24 AM »
The advance is assembled correctly and the pin in the correct position. The battery is brand new and charged. The headlight hi / lo switch is a little finicky so the headlamp I actually able to be turned off. The plugs are correct NGKs and the caps are stock. We trimmed the leads and firmly seated the caps. I also cleaned the points with light sand paper. I have not tested the condensers.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Ryan66
« Reply #7 on: March 02, 2021, 09:21:27 AM »
Got $1 on condensors. Theres a reason why they are so cheap
1976 CB550k (cafe project)
Offline Deltarider
  • I'm back
« Reply #8 on: March 02, 2021, 09:41:25 AM »
It is weird indeed. Maybe this vid is helpful. At the breakerpoints a tiny bit of sparking is normal, excessive sparking or arcing is not good and can indicate a bad condenser. So in this vid the left condensor (1+4) is bad, right condensor (2+3) is good.
And it is always good to ask yourself: what else have I touched (= worked on) lately?
You are not using a stroboscopic timinglight that has a dial, are you?
« Last Edit: March 02, 2021, 09:42:57 AM by Deltarider »
Offline jakec
« Reply #9 on: March 02, 2021, 10:15:53 AM »
Thanks for the video. it is not arcing like that. only a tiny arc for both. And I have not been able to get the bike running yet, so this static timing.
Re: what else have I touched, when I noticed that 1 & 4 weren't sparking I swapped another identical coil of a cb500 onto the bike. But it didn't make any difference with the symptoms.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #10 on: March 02, 2021, 10:22:31 AM »
I did not see the arrows first time I viewed this. I have cleaned up many points advancers before and never knew there was an index mark. I will check that asap.
edit: I just checked and the index mark was off 180*. What effect would this have? I assume it would resolve the issue where I had to cross the blue & yellow wires.
« Last Edit: March 02, 2021, 11:03:38 AM by jakec »
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Menno
  • www.tanklackieren.de
« Reply #11 on: March 02, 2021, 01:14:19 PM »
So... are the points new?
Because often points don't wear out between the points but on the carbon part that runs against the points cam.
On the condensators there is a clamp to hold a piece of eh wool(?) (don't know the English word).
This should run against the points cam and should be oiled.
If this runs dry the points will wear really fast losing millimeters on the carbon of the points.
Trying to install them correctly will be unsuccessful.
By new ones.
Offline jakec
« Reply #12 on: March 02, 2021, 01:23:19 PM »
If I can see the points opening doesn't that negate that theory?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #13 on: March 02, 2021, 08:09:57 PM »
I tested the 1.4 condenser and it was good. I did notice that the condensers were touching so I mounted them to not touch. I also flipped the advancer. I was then able to get a much stronger and comsistent spark and set the timing. So it should be problem solved.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Deltarider
  • I'm back
« Reply #14 on: March 02, 2021, 11:00:01 PM »
See little white frames in pic below.
Yes, it would.
I tested the 1.4 condenser ...
How did you test?
Congrats, you've solved the problem,
« Last Edit: March 02, 2021, 11:07:22 PM by Deltarider »
Offline Bodi
« Reply #15 on: March 03, 2021, 06:12:07 AM »
"Plug 3 only fires on F1.4. Plug 4 only fires on F2.3
Plug 3 only fires on F2-3 Plug 4 STILL only fires on F2-3."
This is not weird, it's impossible. You have two coils, one for 1&4 the other for 2&3. You state that the secondary (plug) wires are connected correctly although that doesn't matter here. One plug fires on F1-4 and the other on F2-3, you swap the primary (points) wires around and the first changes to F2-3 but the other stays on F2-3... you see the issue, right? Where is the second coil firing from? Nit the wire to the points that you swapped or it would have to be on F1-4.
Offline jakec
« Reply #16 on: March 03, 2021, 01:16:11 PM »
I think the problem was the condensers were "sort of" touching which was causing the spark to be really weak and inconsistent.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #17 on: March 03, 2021, 02:09:36 PM »
Condensers touching wouldnt do it, they are both boltedto ground
Offline Menno
« Reply #18 on: March 03, 2021, 02:36:11 PM »
No. Because the height of the carbon on the points is lower you will be turning the points further to the left (or right) to let them open...
« Reply #19 on: March 03, 2021, 06:26:22 PM »
If the points cam is in the advancer backward, this is what happens.
Offline Deltarider
  • I'm back
« Reply #20 on: March 03, 2021, 10:48:56 PM »
When not paying intention, the forked terminal of a condenser can touch the plate intermittently (for instance via the crosshead 2+3). It is rare, but it can happen. Hard to diagnose.
Offline jakec
« Reply #21 on: March 04, 2021, 10:55:48 AM »
Well I was able to get the stronger consistent spark and set the timing after doing these fixes in any case. However we went to start up the bike last night and still nothing. We have rebuilt carbs (checked 3 or so times), new battery, fresh fuel & plugs, not set timing. Not sure what can be the problem now.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #22 on: March 04, 2021, 10:59:30 AM »
It reminds me of when I was working on my 400 last summer. Everything was theoretically good to go but it just wouldn't run. Then I bought some new coils and it was good to go.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline goodtryer
« Reply #23 on: March 04, 2021, 11:24:29 AM »
have you confirmed fuel flow?
check that fuel comes out when you open each bowl drain
are the plugs wet?
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline jakec
« Reply #24 on: March 04, 2021, 12:02:19 PM »
Yes & yes...
We are having fuel to all 4 carbs. And have seen wet plugs after attempts to start.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
