Author Topic: 1975 Amen Chopper  (Read 42808 times)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: 1975 Amen Chopper
« Reply #150 on: April 27, 2021, 04:23:12 PM »
Choppers are addictive, hey?
Offline BenelliSEI
  • 1969 cb750
« Reply #151 on: April 27, 2021, 06:16:38 PM »
Yes! It’s a beast, and pleasantly different than all my other projects..... today I noticed the front disc is such a small diameter that the brake pads are only about 60% in contact with the disc surface. Either the caliper needs to be closer to the axle centre (very unlikely), OR I need a larger disc. Looks like it came off a go cart. Mmmm.
Also been checking out “Hensley Performance” (Gary Hensley). Based on the KZ1000 carbs, the engine is likely closer to 900cc’s than 736. The original owner told me it has “alloy rods and big pistons”. Could not recall the details.
« Last Edit: April 27, 2021, 06:20:23 PM by BenelliSEI »
  • Gusto mo titi ko?
    • project
1975 Amen Chopper
« Reply #152 on: April 27, 2021, 06:41:08 PM »
I can’t see any of your pics. Have you id’d the wheel, disc, or caliper? Is it a hurst airheart caliper? The make different sized rotors.
***EDIT***
Is that a dual disc hub? I’m noticing 6 bolt holes on the opposite side. That looks like a hallcraft hub. h/a rotors should fit, and are still available!
« Last Edit: April 28, 2021, 05:20:34 PM by Medyo Bastos »
Offline BenelliSEI
  • 1969 cb750
« Reply #153 on: April 28, 2021, 04:26:15 PM »
Good question, I have no idea! When I can post pictures I will show it to you.
Offline BenelliSEI
  • 1969 cb750
« Reply #154 on: April 28, 2021, 04:27:02 PM »
Picture attempt...
It’s working! Will post photos tomorrow
« Last Edit: April 28, 2021, 04:29:58 PM by BenelliSEI »
  • Gusto mo titi ko?
    • project
« Reply #155 on: April 28, 2021, 04:51:36 PM »
What did you do differently?
Offline BenelliSEI
  • 1969 cb750
« Reply #156 on: April 28, 2021, 06:18:16 PM »
Reported the problem and it’s been fixed?
Finished up the tune up and put all the electrics back. Added a few fuses and did some clean up. Original tail light bracket painted, new tail light (repro) and back together.
« Last Edit: April 28, 2021, 06:20:17 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #157 on: April 28, 2021, 06:22:17 PM »
***EDIT***
Can you see pics now? Appreciate if you recognize the front brake? I’ll take good pictures tomorrow.
Offline Tom
« Reply #158 on: April 28, 2021, 06:59:31 PM »
Yes can see your pics now John, the bike is looking Awesome
'59 T120.,'70 T120R Had one new.,'69 CB750 Oz Sandy Ruby Red.,'69 CB750 Oz Sandy Blue Green.,'70 CB750 K0 Candy Gold.,'71 CB750 K1 Valley Green I bought new.,'71 CB750 K1 Candy Garnet Brown.,'76 Rickman Honda CR750 R.C. Eng Cobra Powered. Two CB750 Choppers a Amen Saviour and a a Santee rigid arm Softail. A ‘72 Z1 Jaffa, and lotsa fun Honda Monkey bikes.
Offline BenelliSEI
  • 1969 cb750
« Reply #159 on: April 29, 2021, 12:06:35 PM »
Thanks Tom! Here’s a “bling” shot. All the chrome from the headers back, is clean and polished (and there is lots). The switchbox now matches the red on the rest of the machine. The footboards have disappeared and are replaced by the original Amen pegs. Found a reproduction tail light and repaired/ painted the bracket. All the hardware that was painted black was stainless, so I knocked off the paint and polished them up.
« Last Edit: April 29, 2021, 06:36:07 PM by BenelliSEI »
Offline BenelliSEI
  • 1969 cb750
« Reply #160 on: April 29, 2021, 12:10:03 PM »
This switchbox was raw aluminum. Considered relocating it under the carbs, but decided to keep the unit “as built”. The red paint helps it disappear a bit! Added a couple of fuses and cleaned up some over heated wiring while it was apart!
Offline BenelliSEI
  • 1969 cb750
« Reply #161 on: April 29, 2021, 12:13:13 PM »
Added a horn and button (there never was one) to the empty LHS bar control.
Offline BenelliSEI
  • 1969 cb750
« Reply #162 on: April 29, 2021, 12:16:59 PM »
***EDIT***
M/B ....... Here is a picture of front brake. have not dug into it yet. Do you recognize it? Think I can find a larger diameter disc? The caliper can’t be moved closer to the axle centre, but the pads are not fully engaged.
Offline BenelliSEI
  • 1969 cb750
« Reply #163 on: April 29, 2021, 12:19:55 PM »
New tail light and “fresh” lic. plate mount. My red Tremclad rattle can is an excellent match.  Note that even the sprocket nuts and locktabs have been chrome plated! Nothing held back by the original builder!
Just had to reuse the “bullet” hardware on the lic.plate. Crazy stuff.
« Last Edit: April 30, 2021, 09:21:20 AM by BenelliSEI »
« Reply #164 on: April 30, 2021, 12:04:27 PM »
I can probably machine an adaptor for bigger rotor, need to know bolt pattern and offset.
 Maybe look for a  used rotor off a dual purpose bike , then we can build the center carrier..
Offline BenelliSEI
  • 1969 cb750
« Reply #165 on: April 30, 2021, 12:25:20 PM »
Frank.... good idea! I was looking at it today, thinking along those lines. You may have noticed the caliper mount is “clamped” to the two bars and could be moved up a bit (away from axle centre) allowing some extra flexibility on the disc diameter.....
There is a bike “bone yard” (Cycle Salvage) not far from my farm. The guys usually let me prowl around in the back. When the weather improves, I’ll go see what I can find...... it’s a very thin disc, with almost no offset.
« Last Edit: April 30, 2021, 12:27:40 PM by BenelliSEI »
Offline CBJoe
« Reply #166 on: April 30, 2021, 05:31:45 PM »
I freaking love those style chopper frames with that rear shock setup.  Bike looks great  8)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #167 on: April 30, 2021, 06:38:48 PM »
 Polishing the diamond, I like it. I like to pay homage to the PO's and just improve their bike except when their work has a major negative effect. (My opinion though)
  My K2 had +6" forks lowering blocks and a hog rim. Handlebars like if you put your hands straight forward and close together with your thumbs up I didn't even like moving it around the shop. I got some cb400F bars for it, sorry Dick.
Offline scunny
  • don't call me expert
« Reply #168 on: April 30, 2021, 07:11:36 PM »
Damn, I want a chopper now. Have mercy on my soul.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BenelliSEI
  • 1969 cb750
« Reply #169 on: April 30, 2021, 07:32:24 PM »
STOP LOOKING! That’s what got me here.......!
  • Gusto mo titi ko?
    • project
« Reply #170 on: April 30, 2021, 07:36:37 PM »
I’m sure I’ve got at least 1 I could spare!
Offline BenelliSEI
  • 1969 cb750
« Reply #171 on: April 30, 2021, 07:37:58 PM »
I agree! Must be a lot of preload on those springs! I think I’ll leave them alone for now.
  • Gusto mo titi ko?
    • project
« Reply #172 on: April 30, 2021, 07:41:15 PM »
There is no dampening. You will get more pogo than you’d expect. Some love them, and some hate them. It’s a matter of preference.
« Reply #173 on: April 30, 2021, 09:33:38 PM »
I cant say it was a bad ride.. i cant remember it ever doing a pogo or continue bouncing.. i put a lot of miles on it.
 I have done 5000 miles in a month, and over 800 kikes in a day on the one I had.,
 Now some of the other plunger frames, have way more slpp, and things moving around as you insert axle..
Offline 1080
« Reply #174 on: May 01, 2021, 08:57:42 AM »
My P&P girder had no Poggo effect, I did take my brothers 650 Kaw with his springer for a ride, and yes you know that poggo effect. A friend of mine also with a custom 750 springer, also did not like the poggo effect. I suggested to do what Harley's did to solve the problem ( See 1990 Harley softail/springer model). So even if yours is a girder with springs, you may also go this way to damp the bounce.
« Last Edit: May 01, 2021, 09:22:21 AM by 1080 »
