Author Topic: CB750F2 77-78 Swingarm  (Read 637 times)
Offline DartFrog68
« on: March 02, 2021, 08:39:53 AM »
I have a 1977 Honda CB750F2 super sport model and I've noticed that the rear swingarm is asymmetric (sprocket side is further from the centerline than the brake side) and wider than that of the earlier '76 F models and the K models which were symmetric. I was planning on fitting the spoked hub from a '76 F model with the disc brake so I could convert the current comstar wheels to spoked wheels but I'm assuming the '76 hub won't fit on the '78 swingarm. Does anyone know why the '78 model swingarm is wider than all the other CB750 swingarm designs? Would I be able to swap out the hubs if I used a '76 swingarm and modified the rear suspension mounting points on the frame or would I end up with other clearance or alignment issues down the line?
Offline slikwilli420
  • Master of Disaster
Re: CB750F2 77-78 Swingarm
« Reply #1 on: March 02, 2021, 09:34:34 AM »
If you want to use the spoke wheel, you will need the later sprocket carrier for your swingarm and it will fit into the spoke hub. They were offset to make room for the 630 chains Honda started using in '77, which is total overkill now, so if you need sprockets, do yourself a favor and convert to 530 chain.
« Reply #2 on: March 02, 2021, 10:15:43 AM »
Spacers etc are the same. As stated it's the sprocket carrier that has the 10mm offset.
« Reply #3 on: March 02, 2021, 02:04:12 PM »
Sprocket holders MUST use the correct length INNER spacer..
