Author Topic: Electrical cut-out CB550  (Read 638 times)
Offline 1977_cb550k
« on: March 06, 2021, 01:26:19 PM »
Hi folks,
Was all kitted up and ready to ride today with a couple of mates.
Turned the key and the engine/oil/neutral lamps were lit up fine. All normal. And  then 5 seconds later complete cut-out of the indicator lights. Dead.
Checked the fuses. All fine. Tested the battery - 12.7v charge, fine?
Checked visible electrical cables, couldn’t see any issues (my cables are in good nick).
Any clues what would cause that cut-out but not burn a fuse?
1977 CB550k3
Re: Electrical cut-out CB550
« Reply #1 on: March 06, 2021, 02:49:12 PM »
Check the fuses with a metet not just visually, the clips holding the fuses go soft and dont hold the fuses tight which overheats the eend cap and unsolders the element---fuse looks good but no current path.
Hondaman makes a blade type fuse boxdirect replacement
Offline 1977_cb550k
« Reply #2 on: March 06, 2021, 04:02:49 PM »
Thanks Bryan.
Replaced all fuses and still no luck.
1977 CB550k3
Offline Bodi
« Reply #3 on: March 06, 2021, 05:26:45 PM »
First I would measure battery voltage with the keyswitch on. I have seen several batteries fail so that they read good voltage but can't power anything: some internal failure that causes a very high internal resistance. If it's ok...
Most likely is the keyswitch, the rear plastic housing (the actual switch part) gets brittle and the holding tabs break, then the back comes loose. The harness plug can also work loose.
Or the ground or power cable from the battery has a poor connection. Shorting the starter solenoid studs with a hefty screwdriver will tell if there's power and ground for the starter, at least.
If no starter spin, look into the battery cables for ground and battery pos. If it does spin... the harness battery power wire (red with an extra insulating sleeve) goes from battery pos to one end of the MAIN fuse, either directly or from the solenoid input stud. So if you have no voltage from battery neg to the fuse ends, check that power wire.
And look inside the fusecase, the back pries off. Overheating from poor connection to a fuse (MAIN carries the most current) can melt the solder so the wire falls off or gets an intermittent connection, can even arc and burn away.
« Last Edit: March 07, 2021, 03:09:25 PM by Bodi »
Offline goodtryer
« Reply #4 on: March 06, 2021, 07:47:51 PM »
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline newday777
« Reply #5 on: March 07, 2021, 05:26:47 AM »
Do you have an Emgo ignition switch on the bike?
Stu
My current rides
Prior bikes....
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #6 on: March 07, 2021, 05:42:00 AM »
ignition switch
cb750 k6 - ugly
Offline Shtonecb500
    • Youtube profile
« Reply #7 on: March 07, 2021, 09:15:22 AM »
most of my problems like that have been my ignition switch going dead, its happened to me 3 times.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline 1977_cb550k
« Reply #8 on: March 07, 2021, 02:38:19 PM »
It's an original ignition switch. I'll check it, and the harness/connections from it - and report back (next weekend).
1977 CB550k3
Offline 1977_cb550k
« Reply #9 on: March 11, 2021, 10:29:55 PM »
OK. got to the bottom of my problem. It wasn't the ignition switch.
The charge system was over-charging at ~16V and it cooked my battery.
Installed new battery and adjusted the points gap slightly to bring charge rate down to 13.7V.
Sorted (for now).
1977 CB550k3
