Author Topic: Who has CR29 carbs - stiff when the bike is running  (Read 543 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 12, 2021, 07:01:35 PM »
Took the bike (‘70 CB750/836)  out the other day after almost 6 months.  A couple days before, I took the CR29 carbs off and cleaned them and moved the needle down 1 notch.  Really didn’t need much.
Anyway, when the bike is not running the throttle/cables etc are very smooth both pulling and pushing.  Snaps back crisply.   But, when the bike is running, the throttle gets tight.  Will just about act like a cruise control and takes noticeably more effort to twist the throttle.
Cables are recent, lubed and silky smooth.  Throttle tube is also recent.
Any ideas?   I don’t remember them like this.  Nothing is binding.  Throttle action is smooth from lock to lock.
Carbs are CR29s  only have about 3000 miles on them.
Any ideas?
« Last Edit: March 16, 2021, 12:18:48 PM by greenjeans »
Offline robvangulik
  • Honda Fourever
Re: Who has CR carbs - stiff when the bike is running
« Reply #1 on: March 13, 2021, 01:45:35 AM »
The only difference between running and not running should be the vacuüm pulling on the slides and the fuel flowing through the pipes and jets. I can''t see the fuel making a difference, but if the carb wall is bit rough where the slide is pulled against it, it could, maybe a bit of polishing could help?
Offline newday777
« Reply #2 on: March 13, 2021, 05:22:41 AM »
Maybe you should edit the title to ....
Problem with CR29 Carbs- stiff when bike is running
That might get attention
Stu
My current rides
Prior bikes....
Offline Tim2005
« Reply #3 on: March 13, 2021, 08:00:54 AM »
Those CRs do get stiffer when the motor is running, I had to fit the push cable to mine to stop them hanging at times, though they would snap shut nicely with the engine off. I wonder if your return spring lost some of it's strength too?
Offline greenjeans
  • 1972 CB750K2
Re: Who has CR29 carbs - stiff when the bike is running
« Reply #4 on: March 16, 2021, 12:19:11 PM »
Had to read that twice.  :)
