Author Topic: Main jet threads?  (Read 1190 times)
Offline The Gurg
Main jet threads?
« on: March 22, 2021, 04:35:48 PM »
Are these threads ok? 4th turn down has a small section that looks rough. The main jet doesn’t thread all the way, which is the way it’s supposed to be I think. But with less thread engagement, wanted to see if this was a concern. The rest of the threads further down and on the opposite side look good.
CB750K5 Keihin Carbs
« Last Edit: March 22, 2021, 04:47:56 PM by The Gurg »
Offline robvangulik
  • Honda Fourever
Re: Main jet threads?
« Reply #1 on: March 22, 2021, 04:39:45 PM »
The emulsion tube threads in there,the main jet should thread in that tube completely.
Offline The Gurg
« Reply #2 on: March 22, 2021, 05:01:31 PM »
Oh oops, I misspoke/mistyped. Main jets seated. I meant the emulation tube has threads showing. You can see that in the second picture.
« Last Edit: March 22, 2021, 05:04:40 PM by The Gurg »
« Reply #3 on: March 22, 2021, 06:05:01 PM »
That will be fine, more than enough threads to hold, just dont go he-man with a 4foot spanner
« Reply #4 on: March 22, 2021, 06:08:32 PM »
 Yes its normal for threads on the emulsion tube to show. Too much force can crack the carb body or break the threads. I've seen pictures where they were cranked down so hard the small end of the emulsion tube was bent and deformed.
« Reply #5 on: March 22, 2021, 06:23:06 PM »
Looks perfectly normal!
The main thing is: the tip of the emulsifier is the venturi at the needle, under the slide. It should stick up between 2.5 and 4.5mm into the throat of the carb.
Offline The Gurg
« Reply #6 on: March 22, 2021, 06:45:29 PM »
Hondaman-
Like the emulsifier threads in 2.5 to 4mm deep? I’m thinking that’s what you mean.
Ekpent-
That’s what I thought, thanks for confirming!
BryanJ-
Had to use a 1/2 to 3/8 adapter and then a 3/8 to 1/4 adapter to get a 7mm socket to fit on my breaker bar, am I doing it right?
« Last Edit: March 22, 2021, 07:46:59 PM by The Gurg »
Offline Bodi
« Reply #7 on: March 22, 2021, 10:04:00 PM »
No. The emulsion tube incorporates the needle metering orifice. That part, the inner end of the tube, should stick up into the carb throat under the slide and project 2.5 to 4.5 mm above the bottom of the throat bottom. Usually no problem but sometimes some goop or corrosion blocks the tube from bottoming.
« Reply #8 on: March 23, 2021, 12:18:34 AM »
You forgot the 1 inch to 3/4 and 3/4 to 1/2 adaptors Luke
« Reply #9 on: March 23, 2021, 12:43:16 AM »
Easy to make mistake when removing tbe tube when carbs are mounted on bike. Tighten instead of removing.
I always use a 1/4 socket wrench I carefully check, removal only to not make mistale stripping the threads.
I have been close once back in the days. Changed procedure after that.
Offline The Gurg
« Reply #10 on: March 23, 2021, 08:01:56 AM »
Bodi/Hondaman-
The throat in my keihins have a small brass fitting (the brass fitting being the Venturi I think?) that the needle goes through at the throat floor. So the emulsion tube can’t thread through into the throat because that fitting blocks it. Do you mean that the emulsion tube seats against the underside of that small brass fitting?
BryanJ-
Ah I see the problem, my breaker bar only has a 1/2” drive. Do you think a 1” drive four foot long  handle breaker bar is something I could find at Target in store? Can’t seem to find a name brand spanner on Amazon.
Offline 69cb750
« Reply #11 on: March 23, 2021, 08:49:47 AM »
Yes, the main jet holder seats against the needle jet.
« Reply #12 on: March 23, 2021, 10:50:36 AM »
Luke i'm glad you get my humour and nah dont bother with the breaker just nip to the nearest commercial tyre shop and use there 18 wheeler air gun😂😂😂😂
Offline The Gurg
« Reply #13 on: March 23, 2021, 03:57:45 PM »
Haha I’ll take the suggestion under consideration!
Offline The Gurg
« Reply #14 on: March 24, 2021, 02:25:42 PM »
Just remembered, have an emulsion tube on carb number one that is shorter than the other three emulsion tubes(wrote this post when I was working on carb 3). Doesn’t show threads and seats fully into the carb body. I measured (but it was a couple days ago, and I was checking how much thread I should see, not determining seating at the needle metering orifice) and it’s close if not exact to the length to seat against the needle metering orifice. Could have a small gap though. Should I remeasure, swap out the emulsifier, or is it good?
Of course it ran that way for 8 years since the last carb rebuild. Did have low compression on the first cylinder before I pulled it apart. Don’t know if that somehow could have contributed? Could see a gap causing turbulence just under the needle metering orifice that results in a lean mix damaging the piston rings, et cetera?
« Reply #15 on: March 24, 2021, 07:40:30 PM »
Tube shorter is not good, if screwed in father main jet will not be as deep in the gas and that could affect mix.
Q has the tube been shortened or is it from a different bike?
