Author Topic: 1975 cb550f  (Read 10724 times)
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: 1975 cb550f
« Reply #50 on: September 06, 2023, 09:03:01 AM »
coming along nicely.
good to see one come back from the brink
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Scott S
Re: 1975 cb550f
« Reply #51 on: September 10, 2023, 05:32:40 AM »
 Leave the exhaust in black ...looks good and the header looks to be a genuine 550F header (with a cone welded on), so it has some value in itself.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Fezzler
Re: 1975 cb550f
« Reply #52 on: September 10, 2023, 03:05:18 PM »
Good counsel.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Fezzler
Re: 1975 cb550f
« Reply #53 on: November 06, 2023, 09:35:50 AM »
Well, unknown source of lack of sense of urgency to complete continues as does commitment to do it right to the best of my abilities.  Forks and wheels are done and many parts on hand, so progress certainly has the means to accelerate.  Reminder, salvaging someone else's abandoned project.
Offline Fezzler
Re: 1975 cb550f
« Reply #54 on: November 01, 2024, 05:43:10 PM »
Better late than never?
« Last Edit: November 02, 2024, 09:36:28 PM by Fezzler »
Offline Little_Phil
Re: 1975 cb550f
« Reply #55 on: November 04, 2024, 08:28:41 AM »
Step by step and each one looks good.
Re: 1975 cb550f
« Reply #56 on: November 04, 2024, 09:51:31 AM »
TrueDisk can surface your disc so it is flat and both sides are parallel. They also offer drilling services for better wet weather brake performance.
https://truedisk.net/
Fwiw
« Last Edit: November 04, 2024, 09:54:31 AM by RAFster122s »
Offline Fezzler
Re: 1975 cb550f
« Reply #57 on: November 04, 2024, 09:27:19 PM »
Fwiw
Good to know!  A++
Re: 1975 cb550f
« Reply #58 on: November 05, 2024, 07:11:36 AM »
Absolutely!  And looks great, nice job...
Offline Fezzler
Re: 1975 cb550f
« Reply #59 on: November 05, 2024, 06:00:44 PM »
Means a lot coming from you.  I procured the bike.  It took me a long time to find someone to weld the hoop on the frame.  I did order parts and got much elbow grease work done but I lost motivation to get on it.  Motivated now.
« Last Edit: November 05, 2024, 06:02:26 PM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #60 on: November 08, 2024, 09:43:50 AM »
... onward. D-shaped washer time.  Find. Buy.  Or make.
« Last Edit: November 08, 2024, 09:46:02 AM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #61 on: November 08, 2024, 11:14:47 AM »
I knew I had an extra set somewhere around here.  Bow to the stash!
Re: 1975 cb550f
« Reply #62 on: November 09, 2024, 10:41:33 AM »
Make is tough given the thickness, std washers are too thick
Thankfully a member came to rescue having proper thickness washers made up...
Offline Fezzler
Re: 1975 cb550f
« Reply #63 on: November 09, 2024, 12:07:28 PM »
Indeed!  Johnnie on the spot!
Offline Fezzler
Re: 1975 cb550f
« Reply #64 on: November 09, 2024, 04:26:20 PM »
Trying to maintain newly found momentum.  I was going to install more modern, minimalist headlamp brackets but I just like the look of gaiters.
Re: 1975 cb550f
« Reply #65 on: November 11, 2024, 08:37:15 AM »
... but I just like the look of gaiters.
Agreed, it just a classic look.
When I was doing a project that I didnt want to stall, I found doing just 1 thing everyday, no matter how small, seemed to help keep progress.
Offline Fezzler
Re: 1975 cb550f
« Reply #66 on: November 11, 2024, 11:59:28 AM »
Wise.  Yes.  Even if it is cleaning, finding bolts/washers, or thinking ahead.
Offline Fezzler
Re: 1975 cb550f
« Reply #67 on: November 11, 2024, 03:42:23 PM »
SOHC/4 mentor gave me great idea to salvage a stock brace off unusable front fender to rivet a new one on.  I will fill holes (JB Weld?), add hole for speedo grommet, and paint.  On second thought, the holes are uniformly spaces and small, two in front and two in back.  I may just drop a rivet in them.  Once painted, it will look fine.
« Last Edit: November 12, 2024, 01:01:15 PM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #68 on: November 11, 2024, 03:45:23 PM »
Also thinking about rear fender and lighting.  Bullets definitely upfront.  I have a matching set for rear that I am thinking about pairing with a thin light under the fender.  I believe I need to have a license plate light in North Carolina.  The round ones below have that.  Hmmm.
« Last Edit: November 11, 2024, 03:57:35 PM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #69 on: November 11, 2024, 04:05:43 PM »
I wish previous owner did not remove the clips for the plastic part of the rear fender.  Even with the shorty fender, seems good to install to lessen road grime on engine.  May have to think about alternative, safe, stable, effective way to mount.
Oh, looking below, the farthest crossbar was added by previous owner to attach a racer-style cafe seat and shell.  I added the closest one to attach my seat.  I figured having both would be good for making the frame solid and provide options for attaching the rear fender and something unanticipated.
« Last Edit: November 11, 2024, 04:10:27 PM by Fezzler »
Re: 1975 cb550f
« Reply #70 on: November 12, 2024, 06:42:59 PM »
Nice work. Are you referring to plastic clip for the plastic liner or metal tabs the clips attach to? Rubber well nuts might be good mounting solution if they trimmed the plastic fender for so.e reason. I haven't had my 550 apart in this area, so forgive me if my assumptions are wrong here.
Offline Fezzler
Re: 1975 cb550f
« Reply #71 on: November 12, 2024, 07:27:37 PM »
Now I don't know if I would use it or how it would look.  But yes, I am talking about the black inner plastic fender / liner.
See picture.  On the down tube there are three tabs or clips that secure it in place on both sides.  It wedges in there.  The previous owner removed these.  I have not addressed yet, but will be thinking about if there is an effective way to use without welding on the powder coated frame.
Offline Fezzler
Re: 1975 cb550f
« Reply #72 on: November 13, 2024, 07:43:34 PM »
Cheap shorty front fender mounted on factory bracket and getting multiple coats of rattle can semi-gloss black and some clear.  Done.
« Last Edit: November 13, 2024, 07:45:56 PM by Fezzler »
Offline Fezzler
Re: 1975 cb550f
« Reply #73 on: November 24, 2024, 06:58:14 PM »
Slow and steady.
Re: 1975 cb550f
« Reply #74 on: November 25, 2024, 07:15:17 AM »
What tire is that fezz?
