Author Topic: ‘78 750A can’t keep it running.  (Read 1230 times)
Offline wingedwheel
« on: March 27, 2021, 07:07:46 PM »
Hey guys, been working on restoring a ‘78 that lived outside under a tarp for 22 years. I have rebuilt and redone almost everything on the bike. Carbs are pristine, timing is spot on and bike will start by spraying gas in the carbs but will not run. Could it be it be intake boots? I did not replace them yet and they are harder than I like. I’m really getting tired of this project as it has fought me every step of the way and I’m right at the finish line and hate to give up.
Offline dave the welder
  • dave the welder
Re: ‘78 750A can’t keep it running.
« Reply #1 on: March 27, 2021, 08:04:28 PM »
are you getting gas to the fuel bowls? check petcock to see if its plugged
don't buy it build it
« Reply #2 on: March 28, 2021, 12:36:44 AM »
Photo has no air box with filter.
No filter/less restrictive filters need richer jets.
Offline wingedwheel
« Reply #3 on: March 28, 2021, 04:36:10 AM »
I’ve got fuel to the bowls. I actually had it idling them pulled the carbs back off to check a setting and when I put them back on I could t get it to start after that. I figured moving those boots may have caused that. I can actually move them with the clamps tight so that’s why I suspected them.
Offline newday777
« Reply #4 on: June 19, 2021, 06:20:44 AM »
Good boots are a necessity to get proper vacuum flow/draw.
Stu
My current rides
Prior bikes....
