Author Topic: Final drive chain and sprocket lubrication  (Read 721 times)
Offline caluser2000
« on: April 02, 2021, 05:11:38 PM »
Over the years I've used a number of oils to lubicate my bike final drive chain and sprockets:
Engine oil
80W gear box oil I had to get rid a 4ltr pack for a car we had gotten rid of. Took around 10 years ;)
Graphite based and dry lubes of various types on O-Ring chains.
Now CRC Tac-2 which I am am very happy with on the CB550 standard chain and XF650s X-Ring chain.
What have you al used in the past and happy with now?
« Last Edit: April 02, 2021, 05:23:00 PM by caluser2000 »
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline Killer Canary
  • Typical Bran Muffin
Re: Final drive chain and sprocket lubrication
« Reply #1 on: April 02, 2021, 05:31:12 PM »
Really?
I thought x and o ring chains were verboten on the 550.
What brand are you using?
I wouldn't mind one on the Canary.
Kawi GPz900, H1
Offline caluser2000
« Reply #2 on: April 02, 2021, 05:35:41 PM »
Really?
The CB550 has a standard chain as I posted it. The XF650 Has ab X-Ring chain as I posted it.
« Reply #3 on: April 02, 2021, 05:49:13 PM »
Indeed, as you posted it.
Read more carefully, Canary. ;D
I've never heard of that xf650 critter before.
Kawi GPz900, H1
Offline caluser2000
« Reply #4 on: April 02, 2021, 05:53:39 PM »
It's a fun ride. Similar power output as my CB550F. More in lower rev range though. 100lbs lighter than the CB550F
Has a DR650 donk running bigger valves, two spark plugs in the head and two carburetors.
Less than 50 were bought in to New Zealand. None went to the US.
First pic is the day I test road it.
Second pic Goat as he is now.
« Last Edit: April 02, 2021, 06:21:15 PM by caluser2000 »
« Reply #5 on: April 02, 2021, 07:50:33 PM »
I will only use sealed chains. (sorry 550 owners, I don't own one) I really don't lube them until they start to show signs of their life ending, then I have had good results with Bel-Ray Black.  The real lube is inside the seal.  Just keep them clean by scrubbing down with wd40 soaked rag.
« Last Edit: April 02, 2021, 07:53:09 PM by seanbarney41 »
