Author Topic: Carburator float post repairs LASER WELDING W/pictures  (Read 22047 times)
Offline Jim F
  • go baby go
Re: Carburator float post repairs LASER WELDING W/pictures
« Reply #25 on: March 12, 2007, 08:11:17 PM »
I think brazing is much cheaper and doesn't require a super expensive setup. It does the same and looks are of no concern for something like this.
That might work with some applications but you would have to put a lot of heat in the small area to get the bronze to flow
and then maintain that heat to evenly flow the bronze over the cracked area. what is that heat doing to the surrounding area?
Yes this system is very expensive but this is just after my day is over and i can play with my motorcycles and help some people
that might benefit from this type of welding.
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #26 on: March 12, 2007, 11:49:37 PM »
That is mighty impressive work there, Jim.  I don't have any carbs with broken float posts, which I almost lament.
But, I do have some where the main jet tower has corroded away and won't capture or seal the main jet anymore.  Do you think you could do a weld build up that would allow re-machining the carb body in that area?
Offline Jim F
  • go baby go
« Reply #27 on: March 13, 2007, 12:27:57 PM »
I would have to take some of the old corroded material off to get in some good (yeah right.....good metal in a carburetor?) metal and then build it up from there.
it would be strong enough to re-machine then
how much wall thickness do you think there is from the threads to the out side wall?
you can e-mail me at www.jmfmicroweld@earthlink.net
thanks
Jim
Offline rhinoracer
« Reply #28 on: March 13, 2007, 02:50:54 PM »
Impressive technology!. Will you be posting laser welding pics?
Hope you find more applications than just broken carb float posts. 8)
Baja native.
Offline Jim F
  • go baby go
« Reply #29 on: March 13, 2007, 09:42:04 PM »
if you know anything about tool steel welding, that is what my company specializes in
here are some examples
one is made of Beryllium copper and the edge was laser welded with .010 beryllium copper wire
the second one is a 420 Stainless steel insert that was welded using .007 wire
hope these are good examples of what I do every day
the carburetor stuff if play time
enjoy
Jim
Offline Jim F
  • go baby go
« Reply #30 on: March 15, 2007, 08:51:05 PM »
another happy customer for float post repairs
« Reply #31 on: March 15, 2007, 10:09:29 PM »
Beautiful work Jim, I trashed a set of CB750 carbs after busting off a post years ago, so I had to buy another set on Ebay, then with shipping, I spent more than 5 times your repair costs! I might send that busted carb over, if I can find the remains of the post, ha ha! Cheers, Terry. :)
Offline Jim F
  • go baby go
« Reply #32 on: March 20, 2007, 08:52:50 PM »
send them over terry
I do work for a customer who might have some old carbs that we
can bust off a post and make it work
Jim
« Reply #33 on: March 20, 2007, 09:37:23 PM »
Jim
G'Day Jim, thanks very much for that very generous offer mate, but those carbs are in a million bits now, so I won't waste your time. Have you tried welding any pistons yet though?
I've got a wiseco 836cc piston that some dumb shiite (well me, actually :)) tried to force a wrist pin out of, before I realised that the clip was still in place? I could still use it if I used those high temp teflon bushes rather than clips, but I'd rather get it fixed? Cheers, Terry. :)
« Last Edit: March 20, 2007, 11:53:54 PM by Terry in Australia »
Offline crazypj
  • I'm brill, me
« Reply #34 on: March 20, 2007, 10:20:32 PM »
Thats a cool machine.   8)  8)
 I also like the look of the multi position holder, looks expensive all on its own  :o :o
Not that I need it (yet ::)), but could you rebuild a post if necessary? (I can machine stuff but never seen microwelding before, its neat)
Isnt beryllium copper somewhat dangerous, being radio active an all? ( or is it just inhaling vapors when welding/machining?)
PJ
Offline Jim F
  • go baby go
« Reply #35 on: March 22, 2007, 06:28:01 PM »
thanks crazypj,
If you can find an old post or machine one from bar stock then I can weld it but you would need the pivot Axel to make sure
everything lines up
As far as the beryllium is concerned the only thing that you have to be carfull of is the vapors
Ive spent allot of money on a vapor type extractor that I use when I have to weld beryllium
even aluminum or any type of metels that are welded with the laser give off a vapors so the extractor is money
well spent
let me know if I can help you
Jim
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #36 on: March 22, 2007, 06:36:22 PM »
thanks crazypj,
everything lines up
Jim
I used 4 old jet needles to make new pivots for my floats, PO had use some brass rod and things where sticking.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline oldfart
    • The Motorcycle Project
« Reply #37 on: March 23, 2007, 12:10:03 PM »
The carbs are a zinc alloy.  Aluminum rod works for that?
Zinc?  Asian bikes, no.  Pushrod-era Brit bikes, yes.
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
www.motorcycleproject.com
Offline Jim F
  • go baby go
« Reply #38 on: March 25, 2007, 08:09:17 AM »
James,,
Let me know if I can help
as far as wedling zinc its just about impossible with conventional
type tig but have never tried it with the laser
would be interesting though
Jim
Offline Jim F
  • go baby go
« Reply #39 on: March 27, 2007, 11:29:15 AM »
hummmmmmmmmmm
Offline Jim F
  • go baby go
« Reply #40 on: May 09, 2007, 06:33:37 AM »
Here is another project that I did for a buddy up in South Carolina (Hint Hint)
it is a bracket to hold an Idle adjustment from a ZX12
so that you don't  have to raise the seat and get your long screw driver out
adjust on the fly
This was laser welded useing .020 4043 Aluminum wire
Jim
Offline steamnjn23
« Reply #41 on: March 26, 2010, 09:35:20 PM »
bump for the new guys
1976 cb550
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #42 on: March 27, 2010, 08:54:25 AM »
Do you think a front 750 K0 fender could be butt welded using this method? Over the last 2 years I have toyed with taking a later 750 K0-K2 style front fender then dechroming , then chopping off the front and back underneath the stays and then welding cut ends from another fender to recreate a 'double cut version' as used on the Sandcast and early K0's, then rechroming after finishing the welds to a smooth surface. I have measured the the metal thickness and from memory it was about 0.6mm. The Yamiya repros are around  1200USD + import duty + postage!!
Cheers!! AshD
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline haggeo
« Reply #43 on: September 12, 2010, 11:11:57 PM »
amazing.
Offline VTCBike750
« Reply #44 on: September 01, 2013, 08:09:18 AM »
Jim,
Are you still doing these repairs? I have some interesting modifications I looking at gaving repaired.
Adam
-Adam
1972 CB750 (current project)
http://forums.sohc4.net/index.php?topic=87951.0
Offline jamesb
« Reply #45 on: September 01, 2013, 08:59:50 AM »
Another (wow) I have to show my boss this Tuesday. $25.00 seems very reasonable for a repair personally I think your going to have more than that after you buy another set if you figure in the shipping,rebuilding,and hoping the parts set is good or even better than your already working with.
Offline VTCBike750
« Reply #46 on: September 01, 2013, 09:28:02 AM »
I agree, this set was in terrible shape when I got it, the bike was really rough too. They are a whole lot better now except for these crazy holes. Not sure what the advantage is?
I also have this:
 Crack in the #1 main jet area on a set of 657As
« Last Edit: September 01, 2013, 11:42:47 AM by VTCBike750 »
-Adam
Black 750K8
« Reply #47 on: September 01, 2013, 10:45:03 AM »
You should post this here and there is another person here that does the same thing with the same machine. It is nice work
http://forums.sohc4.net/index.php?board=50.0
Offline VTCBike750
« Reply #48 on: September 01, 2013, 11:43:18 AM »
Good idea
-Adam
« Reply #49 on: September 01, 2013, 12:13:42 PM »
Jim has done the post repair for me....fantastic. I will say I am a bit biased as I have spent time with him and talk on the phone with him. You cannot meet a better person.....a great, honest guy. ;)
