Author Topic: 341 baffle removal? NED! New Exhaust Day.  (Read 1197 times)
« on: April 07, 2021, 08:39:31 AM »
 Does anyone remember how to remove the baffles from the 341 pipes? I've ordered a set of repro's from cmsnl and plan to coat the insides with Eastwood inside the pipe exhaust coating before using them. My brother remembers cutting or breaking off a bolt or rivet before he cut the ends off of his new baffles in 1974.
  He sawed off half of the baffles, I don't plan anything that extreme, but you never know.
« Last Edit: April 09, 2021, 02:02:41 PM by Don R »
Re: 341 baffle removal?
« Reply #1 on: April 07, 2021, 03:14:40 PM »
 I've removed other baffles before from other bikes with a bent steel rod attached to the end of a slide hammer set-up.Insert,hook and pull while using the slide hammer gently. The caps on the 341's don't go in deep at all.
« Reply #2 on: April 09, 2021, 08:55:40 AM »
 When my brother mentioned cutting out a bolt, he apparently was referring to a rusted corroded old bolt or corroded baffle. These should just unscrew. I also remember a reference to drilling a rivet but not sure what pipe that was on.
« Reply #3 on: April 09, 2021, 08:56:22 AM »
Offline newday777
« Reply #4 on: April 09, 2021, 08:59:47 AM »
Stu
My current rides
Prior bikes....
« Reply #5 on: April 09, 2021, 10:46:19 AM »
 I'm in no hurry to open them all and expose them to scratches and dings. I will later today and share the pics. One of my yamiya sets came with a matching pair and a missing pipe. DSS got right after that problem.
« Reply #6 on: April 09, 2021, 12:12:26 PM »
 The boxes are labeled a-b-c-d b is #2
Offline newday777
« Reply #7 on: April 09, 2021, 12:14:09 PM »
Good to hear.
What was the total to your location Don?
Stu
My current rides
Prior bikes....
« Reply #8 on: April 09, 2021, 01:58:54 PM »
 I don't have the ticket right here but it was under $1300 with the full heat shield kit, shipping and a spare pillion bolt. Shipping was around $50. Shocking after seeing $500 shipping for the 4-4 racing headers on webike. I do realize Asia is further from me than the Netherlands but wow.
 To me DSS is the shipping deal, he charges a flat rate in the US, it was $17 for my no number pipes but I think it went up to $19 or so.
