Author Topic: 1975 CB550 Cylinder Stud Die  (Read 987 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: April 10, 2021, 05:08:46 PM »
I snapped a cylinder stud on my 1975 CB550. I still have a lot of stud left and was thinking the best method would be to use a die (like in a tap/die kit) to rethread the stud and pull it out. From what I've read on the forum the 750 cylinder stud is a M8x1.25 thread, anyone know if thats the same for the 550? I've never used a tap or die so Im not sure if I should by the right hand or left hand?
I'm guessing the right hand would make a normal thread and the left hand would make a reverse thread? Please let me know if this is right.
I know there is a double nut method to try and get the cylinder stud out, but that did not work when I tried it. So my plan is to get a left hand die and a reverse thread nut, then I would just tighten down the nut and it would cause the stud to reverse out. Let me know if this would work. Thanks!
« Last Edit: April 10, 2021, 05:10:29 PM by campbmic »
Its hard to be wrong when you know nothing!
Offline caluser2000
Re: 1975 CB550 Cylinder Stud Die
« Reply #1 on: April 10, 2021, 05:18:09 PM »
The portion of the sud left is not under any load so once the threads a freed up a pair of vice grips should work. You may need to use something as a lever like say a piece of two inch pipe. A bit of heat will help a well. Ali expands quicery than steel does.
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
Offline campbmic
« Reply #2 on: April 10, 2021, 07:54:03 PM »
I tried vice grips and heat, still wouldnt come out. Thats why I was thinking of using this die idea.
Offline goodtryer
« Reply #3 on: April 10, 2021, 07:59:15 PM »
The double-nut thing should work. Sometimes i have to use a second wrench to hold the locking nut in place. Give that another chance.
Also don't be afraid to use heat & penetrating oil.
"Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles."
-Dostoievski
1977 CB550K
1978 CB750K
1973 CB500K
Offline caluser2000
« Reply #4 on: April 10, 2021, 08:48:46 PM »
Yeah getting those threads losend is the key. Don't use WD40. It's wax and totally hopeless. Use CRC556 or similar.
Offline craz1
  • CDA, Idaho
« Reply #5 on: April 11, 2021, 09:28:03 AM »
If you have split the cases put the upper half into an oven and heat slowly to 425 deg. If your going to replace it anyway just use a small pipe wrench to break the threads free. Mine were a bear to remove. I like using APE studs which allow a bit more torque on the head and cylinders.
« Last Edit: April 11, 2021, 09:43:36 AM by craz1 »
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline flybackwards
« Reply #6 on: April 11, 2021, 09:47:42 AM »
If the studs are like the 750 studs the then the centre portion is thinner - might be a problem to thread it properly and then you have fresh hand cut threads weakening the remaining stud and causes stress points to snap it.
Heat, penetrating oil, soak and repeat a couple of times - then use two sets of vice grips 180 apart and real tight to rotate both directions a bit until you feel it starting to move - patience is key to not damaging the internal threads. Two vice grips allows more torque and also you can feel the movement better.
