Author Topic: Carb Identification Help  (Read 747 times)
Offline dramabean
  • Los Angeles CA
« on: April 18, 2021, 11:59:48 AM »
Hey guys! Working on my 81 CB650c. Looking to run pods on it for a overall cafe look. I know that jetting CV carbs is possible but a huge pain in the ass so I’ve been looking for a set of slide carbs to run.
Found a gentlemen to sell me some but when he sent me pictures they look THE SAME as my own carbs? Is he mistaken that they are slide carbs? Or are my carbs not CV carbs?
His:
My carbs:
Re: Carb Identification Help
« Reply #1 on: April 18, 2021, 12:09:41 PM »
Check the number , and check the spacing, 2 types of spacing on a 650.
 CV carbs have slides, but they are  vacumn operated, vs being controlled by linkage..
Offline dramabean
  • Los Angeles CA
« Reply #2 on: April 18, 2021, 12:12:44 PM »
When I pull the throttle linkage, it opens up a butterfly valve in the back of the body. It does not pull the slide/needle open. I assume it’s a vacuum set up.
« Reply #3 on: April 18, 2021, 12:53:38 PM »
Yes CV  carb, but it does have a slide too... probably what seller is talking about..
Offline Motorcycle jones
« Reply #4 on: April 22, 2021, 10:32:27 AM »
All carbs have slides.
The slides are controlled by pulling on a wire OR by vacuum and spring return.
The reason vacuum operated slides were developed is to compensate for altitude at different
geographic locations. That way Manufacturers did not have to have different jetting in places like Colorado.
« Reply #5 on: April 22, 2021, 10:37:51 AM »
 Those have been painted which will be a pain to clean.
Offline jonda500
« Reply #6 on: April 22, 2021, 04:18:41 PM »
My lawnmowers carb doesn't have a slide, just a simple butterfly valve
John
A starter clutch thread:
« Reply #7 on: April 23, 2021, 08:46:32 AM »
Yeah, a lot of carbs dont have slides, but the 70s and 80s bikes usually did..
