Author Topic: Shaft Advancer threads stripped  (Read 917 times)
Offline wvshooter
« on: April 27, 2021, 07:05:57 AM »
1974 cb750 -
The Shaft Advancer is the roughly four inch long thin stud which the points assembly slides over. A thin nut threads onto the advancer to hold the points assembly in place. The threads on the outside end on mine have stripped. How difficult is replacing the Shaft Advancer? I would like to replace it.
Thanks
Re: Shaft Advancer threads stripped
« Reply #1 on: April 27, 2021, 07:31:49 AM »
 Should screw right out as its threaded in and it has an o-ring on the end also.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: April 27, 2021, 07:44:14 AM »
Make sure you use a new “0” ring and some thread sealer on it.......
« Reply #3 on: April 27, 2021, 09:51:13 AM »
Some come out easy, some come out VERY HARD..
TRY it and see
« Reply #4 on: April 27, 2021, 10:09:30 AM »
Since your threads are stripped you can not double nut it to remove. You will probably have to use vice grips. In my experience they are always a very tight fit.
Offline Progas
« Reply #5 on: April 27, 2021, 12:05:54 PM »
I have a brand new one with a new o-ring if you need one!
Offline wvshooter
« Reply #6 on: April 27, 2021, 02:57:56 PM »
Glad to know I can just back it out, assuming it will back out. Appreciate everyone's reply!
Dave
