Author Topic: 750 heads  (Read 713 times)
Offline fritzer_108
750 heads
« on: April 29, 2021, 02:47:12 PM »
The head on my 1973 cb750 is toasted...warped, cracked, and leaking oil everywhere. I found a $90 head  in great condition from a 1977 cb750...will this fit my bike?
« Last Edit: April 29, 2021, 03:27:22 PM by fritzer_108 »
1970 T120R
1973 CB750K3
1974 CL360
1976 CB750F1
1973 BMW R75/5
1973 Moto Guzzi El Dorado 850
Online bryanj
Re: 750 heads
« Reply #1 on: April 29, 2021, 03:17:58 PM »
Whats a 90 head? And the later 750 had a different oil return path
Offline fritzer_108
Re: 750 heads
« Reply #2 on: April 29, 2021, 03:27:49 PM »
Sorry for the typo...that was meant to read $90.
1970 T120R
1973 CB750K3
1974 CL360
1976 CB750F1
1973 BMW R75/5
Re: 750 heads
« Reply #3 on: April 29, 2021, 03:58:38 PM »
Avoid the 77 f head for sure, I'd try to stay 73-76.   Cycle X does a mod to make late heads not leak oil I'm not sure what it's about.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: 750 heads
« Reply #4 on: April 29, 2021, 04:08:47 PM »
Frankie runs a late f head running external oil lines
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 750 heads
« Reply #5 on: April 29, 2021, 04:45:59 PM »
The 77/78 CB750K heads use a bigger combustion chamber with slightly domed pistons. The 77/78 CB750K head with early flat top pistons will drop compression just a little but it will work. The 77/78 CB750F heads will give you heartburn unless you run it with the 77/78 CB750F cylinders or have the heads worked to deal with the two exposed cylinder studs.
EZPZ  ???
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: 750 heads
« Reply #6 on: April 29, 2021, 11:17:35 PM »
I found a 392 head that had chamber sizes 22.5 - 22.9 cc.
I had expected more.
392 is upside down. I had a thought that it could have come from an Auto or K7.
It looked crappy, but mechanically sound except bad ex guides as used CB750 heads often have.
http://forums.sohc4.net/index.php/topic,180468.msg2128689.html#msg2128689
This is the head my K6 has now after restore this year. All guides  replaced, stock guides adapted for higher lift. Ported, new valves, springs etc.
If bores are tired, bore +0.5mm, use K7 pistons with a 392 head. Work fine with stock K6 head too (300), better compression.
www.cruzinimage.net sell a complete K7 piston kit for $120US + shipping.
« Last Edit: April 29, 2021, 11:20:46 PM by PeWe »
