Author Topic: Z1 or KZ1000 Float Bowls  (Read 1196 times)
Offline BenelliSEI
  • 1969 cb750
« on: April 29, 2021, 02:53:19 PM »
Digging around in the spares that came with my chopper. These shinny float bowls were in a bag. Anyone confirm what they are? Need them?
« Last Edit: April 30, 2021, 07:24:04 PM by BenelliSEI »
Re: Z1 or KZ1000 Float Bowls
« Reply #1 on: April 29, 2021, 03:04:42 PM »
 Look like Mikuni. Google 29mm smooth bore and see if they are the same.
« Reply #2 on: April 29, 2021, 04:15:01 PM »
They fit Mikuni VM series carbs.  I believe one year of the Z1 or maybe even just a certain serial number range came from the factory with those float bowls.  For certain, they were also what was supplied when you bought a set of aftermarket racing carbs, the legendary Mikuni vm29 Smooth Bores.  They have the convenient benefit of enabling the mainjet to be accessed and swapped without removing the carbs from the bike or the floatbowls from the carbs.  Inconveniently, they also lack overflow drains, so if you have float valve problems, gas is either soaking your air filter or going into the oil pan.
« Reply #3 on: April 29, 2021, 06:07:37 PM »
Yes early Zed or maybe the whole  first year had that type of  bowl , with  the jet access..
 It makes sense to have that. DELLORTO uses it too.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: April 29, 2021, 06:33:37 PM »
Thanks guys..... Sean; they do have overflow pipes.....on one side, bent in a bit.
« Reply #5 on: April 29, 2021, 06:40:27 PM »
oh yeah, I see now.  Maybe that is a difference between the Z1 stockers and the Smoothebores
« Reply #6 on: April 29, 2021, 06:43:50 PM »
Thing that really sucks is Z1 Enterprises website used to have a great ID guide for Mikuni VM's, that covered all this information.  `But it is gone now that Dime City bought out the site.
« Reply #7 on: April 30, 2021, 07:03:28 AM »
Need them?
Hey John....interested in the float bowls depending on cost with shipping to TX. [I have a Z1]
Chrome plated, right?
BTW - as Frank and Sean mentioned, jet changes are possible with these w/o removing the entire bowl, a very nice feature.
« Last Edit: April 30, 2021, 07:05:07 AM by Stev-o »
« Reply #8 on: April 30, 2021, 07:40:50 AM »
Need them?
This should please you Steve. 1975 Z1B at Mecum in Las Vegas already hit $24,200. Blue one coming up later this week, will post a result for you ! https://www.mecum.com/lots/LV0121-435191/1975-kawasaki-z1b/
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: April 30, 2021, 09:09:06 AM »
Need them?
Steve-0. ..... PM sent
« Reply #10 on: April 30, 2021, 01:33:39 PM »
Need them?
Very much so, Eric!   Thx for posting
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: April 30, 2021, 07:25:54 PM »
My apologies. I just had a close look at these and they have very small cracks in them. One I tested with water leaks like a sieve. Nice shiny scrap.
