Author Topic: Pistons  (Read 1389 times)
Offline Dan.T
Pistons
« on: May 01, 2021, 02:28:21 PM »
Anyone recognize these?
Offline Dan.T
Re: Pistons
« Reply #1 on: May 01, 2021, 02:30:14 PM »
Helping a friend with a 76 750f. Was planning to do an 836, but I beleive these are 836 already. A stock piston from a 77 750k slides in with about 2mm on each side by my calibrated eyeball. Just curious if we should throw em away or try to find rings
Offline Dan.T
Re: Pistons
« Reply #2 on: May 01, 2021, 02:30:53 PM »
Another
Offline Alan F.
Re: Pistons
« Reply #3 on: May 01, 2021, 03:24:57 PM »
I'd go for some rings.
Got a dial caliper?
https://www.harborfreight.com/6-in-dial-caliper-63730.html
Offline Dan.T
Re: Pistons
« Reply #4 on: May 01, 2021, 03:57:27 PM »
Borrowed a cheap one and I'm getting 64mm on the piston and bore. Will need to verify with a known good one, but this was easily accessed.
Re: Pistons
« Reply #5 on: May 01, 2021, 07:02:45 PM »
64 = 812
If the ring lands are 2.5mm, 1.5mm, 1.5mm then the stock Honda CB350 twin rings will work. From '68 until the 360's came out
Re: Pistons
« Reply #6 on: May 01, 2021, 09:41:20 PM »
I got a set like those, 65mm i think. I too started a thread, no info though..
 They are mentioned at least 3 times in different threads... over the years...
« Last Edit: May 01, 2021, 09:45:57 PM by 754 »
Online PeWe
Re: Pistons
« Reply #7 on: May 01, 2021, 11:31:11 PM »
64mm bore rings are tricky to find. There was a seller 5-6 years ago selling Yoshimura 64 mm rings.
Check if rings have big clearance up-down in grooves.
If they have, pistons are too worn. See Honda CB750 shop manual that specify this clearance.
Better to find new pistons.
836 (65mm) is next step after 64mm.
Bores that need a corrective hone are probably too wide for Dynomans 811 pistons, 64mm.
Correct clearance a must.
Offline teebee67
Re: Pistons
« Reply #8 on: May 02, 2021, 01:49:37 AM »
They look very much like standard Honda 350 (325)K4 pistons which are 64mm.
I'm only old on the outside.
Re: Pistons
« Reply #9 on: May 02, 2021, 05:04:32 AM »
I agree....those are past their prime
Offline valt
Re: Pistons
« Reply #10 on: May 02, 2021, 06:15:50 PM »
Yeah I just looked on the hastings website and they don't even have 64mm rings. If that is indeed what those are, but its easy enough to measure with digital calipers. Also those oil control rings look pretty weird, I would bet that they are pretty old.
Re: Pistons
« Reply #11 on: May 02, 2021, 08:04:48 PM »
 They are one piece oil rings, should be a Honda part.., i got them for my 65mm pistons .. 4th over CB 350.
 Check your ring widths.
« Last Edit: May 02, 2021, 08:20:24 PM by Jerry Rxman Griffin aka MuthaF'er »
Re: Pistons
« Reply #13 on: May 02, 2021, 08:19:40 PM »
Frank he is looking for 64mm
Re: Pistons
« Reply #14 on: May 02, 2021, 09:32:10 PM »
Okayyyyy
. That would be CB 350 std size rings......far as I know..
Offline valt
Re: Pistons
« Reply #15 on: May 03, 2021, 02:39:14 AM »
