Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Carb main jet, float valve seat and bowl drain screw O-ring Sizes for CB350F, CB400F and CB550."Carb O-rings" When rebuilding carbs on the old Honda fours with press-in main jets, you will often find that all the metal parts are fine after a good cleaning, and all that you really need to buy are new O-rings. Honda doesn't sell the individual O-rings separately....instead you have to buy a complete carb kit at $10 to $15 per carb. I found an industrial O-ring supplier who was willing to do small-volume counter sales, and was able to get new O-rings at about 50 cents per carb. Sizes are:Main Jet: 1.2mm cross-section x 3.5 mm IDFloat Seat: 1.5 mm cross-section x 5 mm IDFloat Bowl Drain Screw: AS568-009 (7/32" ID x 11/32" OD)------------------------------------------------------------CB550:Shifter lever seal = inside diameter - 14mm, outside diameter - 24mm, depth - 5mmAnd the one behind the sprocket = I.D - 33mm, O.D. - 57mm, depth - 7mm
