Author Topic: Fixed the aftermarket oil filter bolt.  (Read 438 times)
Offline maxheadflow
« on: May 07, 2021, 08:21:11 AM »
I bought one of those aftermarket filter bolts and found that pressure relief valve was a cheap POS stamped cup and the relief spring was pretty weak.
I lapped the inside of the bolt with a close fitting rod, then made a new cup with about 1/2 thou clearance. Got a new spring from McMaster.
Valve should open at 20psi and be fully open at 26. Probably a little high but I can have a pressure gauge on the bike and can monitor if the filter starts to plug up.
I made a spacer to hold the spring to keep it centered.
