Author Topic: Disassemble air box?  (Read 1411 times)
Offline fxef79
« on: May 10, 2021, 04:33:17 PM »
I feel like a dunce. There must be something I’m missing. I’m trying to fully disassemble a 77 or 78 CB750F air box so I can clean it up, replace or recondition the intake boots, etc. I’ve already run into the problem with the captive nuts on the inner two bolts spinning. But I’m missing something about how the outer two bolts come out. I mean the hex bolts that hold the top and bottom halves together. The bottom half is off and I see what seems to be a round collar on the end of this bolt. That keeps it from pulling out. Does that collar come off somehow? I can’t get a grip on it with anything because you can’t get it up above the surface of the plastic.
What is wrong with me that this doesn’t make sense?  Only thing I can think of is this is a two part bolt?  But the parts diagram disagrees.
Offline fxef79
Re: Disassemble air box?
« Reply #1 on: May 10, 2021, 04:43:35 PM »
Oh hell. Nevermind.
They DO come off. They were just so corroded they were stuck right to the unthreaded part of the shaft. I got my littlest vice grips, pressed down “firmly” on the baffle, and finally managed to just grab the edge of them. Once they freed from the shaft and slid up against the threads I was able to get a better grip and unscrew the bolt from them.
« Reply #2 on: May 10, 2021, 05:17:01 PM »
Boy, that is one CRUSTY airbox! I haven't seen one that bad inside before.
Offline fxef79
« Reply #3 on: May 10, 2021, 06:21:25 PM »
Haha. Of all the threads I start or get involved in, THIS is the one you pop in on. Now I’m embarrassed.
Although, I didn’t let it get this way. This one just showed up in the mail and I’m trying to figure out whether I can make it work on my trike.
I figure if I really screw it up, at least I won’t be screwing up one that was in pristine condition someone might have wanted for their beautiful OEM restoration.
Offline fxef79
« Reply #4 on: May 10, 2021, 06:27:55 PM »
Surprisingly, that picture you see makes it look GOOD. Here’s the filter that was in it.
I think it must have literally been under water.
Offline Flyin900
« Reply #5 on: May 11, 2021, 07:45:54 PM »
That’s hardly broken in yet ...... still lots of life left in that baby!  :)
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: May 12, 2021, 04:36:22 AM »
Oh hell. Nevermind.
LOL! The air box disassembly is not very intuitive. I did a write up of my efforts here:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline fxef79
« Reply #7 on: May 12, 2021, 04:49:45 AM »
Oh hell. Nevermind.
Yes! I even found a piece of the sheared off threads wrapped around the bolt like in your picture and wasn’t sure what it came from.
