Author Topic: Front right motor mounts CB 750 76 and 77  (Read 1035 times)
« on: May 21, 2021, 12:13:47 PM »
I notice there seems to be a change in the mounts, that are drlled through frame and welded in.
 The earlier bikes had a flange head bushing welded in , head is aroud 15mm for a 8mm hole.
 On a 78 i checked it eeemed much smaller like maybe just 12mm straight tubing.
 If you have a 76 or 77 frame without mount on coukd you please check and report. Trying to determine  when change happened. . THANKS
Offline JohnN
Re: Front right motor mounts CB 750 76 and 77
« Reply #1 on: May 21, 2021, 01:31:23 PM »
My January 1976 frame is 8mm, same as my '72 & '74 frames.
CR750 replica
CB750K2
85 VF500F
66 CA160
67 CT90
2000 Triumph 955i
69 Triumph Bonneville
Offline commander60
« Reply #2 on: May 21, 2021, 04:41:06 PM »
I have a 76 and 77
Offline commander60
« Reply #3 on: May 21, 2021, 04:51:26 PM »
This is the 77
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: May 21, 2021, 05:16:17 PM »
Frank..... my K6 and K7 look just like the pictures posted by Commander60. Need more?
« Reply #5 on: May 21, 2021, 05:49:55 PM »
 Thats exactly what i wanted to confirm.
 Looks like the change was in 77 ?  Weird , cuz they actually went heavier on a few things..
 Another weird thing.... is i was not really aware of this till now and  i had a 77 in the 80,s..
 So the late one looks like 14mm od drilled for 8mm bolts.
 And the late is..... will add later...looks  around 25 ish..
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: May 21, 2021, 07:05:36 PM »
And the ‘77 had the fabricated bracket on the left side!
Offline beemerbum
« Reply #7 on: May 22, 2021, 10:53:44 AM »
Anyone know why?
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: May 22, 2021, 02:41:03 PM »
Anyone know why?
Several theories that make little or no sense. One of life’s “great mysteries “.
« Reply #9 on: May 23, 2021, 08:45:17 AM »
Photo from my mid 1975 frame, stamped with K2 number for Europe. Still not washed after rain attacked me on the last 10 minutes of last ride. :(
My K6 look the same as well as an early 1975 frame I have, also EU K2. These 2 have better looking welds. The 4-2-1 no 4 pipe blocked the view for my camera.
Offline Just John
  • Apparently I am a glutton for punishment
« Reply #10 on: May 23, 2021, 02:18:04 PM »
There is a world of difference between the 77-78 frames and earlier frames.
Member
AMA Charter Life Member
AMCA
VJMCA
« Reply #11 on: May 23, 2021, 08:44:13 PM »
There are quite a few differences. Most I have known about for quite some time. This one caught me by surprise..
