Author Topic: Leaking petcock  (Read 442 times)
Offline Kevnz
Leaking petcock
« on: June 01, 2021, 05:04:02 PM »
Sick of your petcock leaking? Mine did even after replacing the rubber disc and o rings. Looks like the issue was the lever. Those wear marks don't look significant, but after resurfacing on a flat plate with wet and dry sandpaper, it now seals properly. Easy fix. Still leaking at the carb though >:(
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline Kenzo1979
Re: Leaking petcock
« Reply #1 on: June 01, 2021, 05:31:09 PM »
Good to know. You should move this over to proven tips and tricks and how to’s.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Flyin900
Re: Leaking petcock
« Reply #2 on: June 01, 2021, 06:09:57 PM »
Significant pot marks in the before picture on the surface which didn't entirely come clean, so it's easy to see how that would leak around the seal area. Fortunately these older petcocks have screws holding them together, not so with the later models with pop rivets requiring careful drilling of the rivet area.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
