Author Topic: Need a cam card for a Megacycle 125-75 cam  (Read 1093 times)
Offline gschuld
« on: June 05, 2021, 06:02:45 AM »
Anyone have specs and or recommendations for proper set up.
1025cc
10.5:1 compression
Ported head
29 carbs
Thanks,
George
Re: Need a cam card for a Megacycle 125-75 cam
« Reply #1 on: June 05, 2021, 09:33:35 AM »
Well of course. PM your phone number and I will text it to you.
Offline gschuld
« Reply #2 on: June 05, 2021, 09:57:12 AM »
Thanks man👍
George
« Reply #3 on: June 05, 2021, 11:58:21 AM »
Satanicmechanic.org spec
125-75 (125-70)
lift/dur/LC
IN  .400     262   105
op/close @0 lash / rec lash
26/56    .005
EX .375      257   104.5
53/24   .005
My timing last year with a 125-75 ( billet cam)
Note! I hade to file cam holders, lobe contact.  I made sure at least 0.25mm clearance.
Ported K2 head 34/28mm valves. 101whp setup on dyno Sept/Oct -2020
Lift In/Ex: 10.0/9.4mm
Open close at 0 lash, 1mm lift:
26/55      dur: 261
55.5/23  dur: 258.5
This year a 392 head 33.5/28.5mm valves.
A little bit later to wish for HP to continue after 9000 rpm ;)
@ 0 lash
IN: 24.5/56.5*
EX: 54/24*
It runs really fine, idle as a stock bike except for it ponds harder due to higher compression.
+195PSI with a cheap tester.
(stock fresh 736 145-150PSI with same tester)
I set valve lash to:
In:  0.1mm
Ex: 0.15mm
« Last Edit: June 05, 2021, 12:10:14 PM by PeWe »
Offline gschuld
« Reply #4 on: June 05, 2021, 04:03:05 PM »
Awesome.
Thanks Per.
George
« Reply #5 on: June 06, 2021, 12:03:01 AM »
Mike must have timing experiences of this cam for various needs?
It will be very interesting to hear how this history will continue! ;D
Dyno chart in blue (101 whp) with 125-75 last year. In open at 26* 1mm (0.04") lift,  0 lash.
« Last Edit: June 06, 2021, 07:46:53 AM by PeWe »
