Author Topic: CR31 setup  (Read 2658 times)
Offline johno
Re: CR31 setup
« Reply #25 on: June 12, 2021, 01:50:59 am »
Hi Jerry,
Its middle of winter here, cold and ugly. I need some entertainment, please go and get both your batboys on the dyno  ;) ;D
cheers johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Re: CR31 setup
« Reply #26 on: June 27, 2021, 06:00:54 pm »
CR31 Update
Old Scrambler popped in. We've been playing. Final, probably, results are in after extensive and exhaustive "conversation".
Elevation: 6900'. 915 CycleX kit. 125/75 cam. JMR Stage 4 head. Pods (big). Kerker with comp baffle
I am totally surprised at the first result!!
Stock Keihin mains at 105! (dropped 2 sizes)
Needles in middle position (raised 1 notch)
62 slow jets (increased 1 size)
Air screws at 3/4 turn
On to tuning the Mikuni RS's and it's a damn good start. And my primaries are not rattling. My cam chain is also new. And the carbs are in sync. Dennis' RS's must have metal slides. He has never heard the RS clackers before LOL
Re: CR31 setup
« Reply #27 on: June 28, 2021, 08:38:48 pm »
What? Did you do a dyno test? And where the hell are you if the elevation is 6900'??
Offline gschuld
Re: CR31 setup
« Reply #28 on: June 28, 2021, 09:02:38 pm »
I believe Jerry is in Colorado Springs CO.  Thin air up thereā€¦..
George
Re: CR31 setup
« Reply #29 on: June 28, 2021, 09:57:25 pm »
The Springs are only 6000'....
Offline johno
Re: CR31 setup
« Reply #30 on: June 29, 2021, 01:19:56 am »
Don't be a hard arse Captain webber, maybe Jerry had a pipe and is 900 feet high  ::)
Offline Old Scrambler
Re: CR31 setup
« Reply #31 on: July 04, 2021, 08:11:11 am »
Jerry lives on the upper EDGE...........of town ;)  He has 45-mph streets and I never saw a squad car :) The conversation was extended to explain how to blend the transition from slow to GO ;D I try to get the jets sorted before I play with the needles ;)
The blue 915-kitted bike is FAST and feels good all around except for the strong throttle spring.  The orange bike with the 1000+cc kit is a very easy bike to ride but will lift the front-end when the new jets are installed and larger ID intakes are obtained. Jerry has two go-fast sleepers and he has taught himself to be quite the mechanic 8)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline johno
Re: CR31 setup
« Reply #32 on: July 04, 2021, 11:28:14 pm »
Thats right Jerry, now ya know how to fix em its time to F#*k em  :o ;D.  ride hard and wear em out :D
Re: CR31 setup
« Reply #33 on: July 05, 2021, 10:22:39 am »
My house is 6885'. North Springs.
