Author Topic: Motoscope Pro, RPM to Dynatek Coil  (Read 821 times)
Offline spectre
« on: June 08, 2021, 08:00:08 PM »
I have looked through a bunch of threads but haven't quite found the answer so I'm hoping to get a little help.
The motoscope pro has a yellow out for tach signal, I have Dynatek 5 ohm coils.
Is it simple as motoscope yellow goes to blue wire (1-4) on dynatek? Or is there something else I need to do?
76 cb550
Offline calj737
  • Moderator
  • I refuse...
Re: Motoscope Pro, RPM to Dynatek Coil
« Reply #1 on: June 08, 2021, 08:23:39 PM »
That’s all. It (yellow) can attach to either coil to get the input signal.
Offline spectre
« Reply #2 on: June 28, 2021, 08:33:55 AM »
Perfect, thx
