Author Topic: 79 CB650 running 74 CB750 Carb, 5000K+ idle when I remove choke.  (Read 688 times)
Offline Fitzy034
Hi Everyone,
Rebuilt an old 79 CB650, running UNI Pods and stock manifold with slip-ons.  Original carb was fine at idle but I could not adjust the needle to increase my fuel as it feel flat after 1/4 throttle.
Purchased a 74 CB750 carb, when I turn the choke off it rockets to 5000RPM.  I purchased new carb boots thinking it maybe a leak and it still will shoot to 5000 once I remove the choke.
Any suggestions would be much appreciated.
Thank you,
Fitzy
Re: 79 CB650 running 74 CB750 Carb, 5000K+ idle when I remove choke.
« Reply #1 on: June 09, 2021, 12:33:10 AM »
Or the slides are too far adjusted or tickover screw too far in
