Author Topic: What kind of screwdriver?  (Read 599 times)
Offline Kevin D
  • SE Michigan
« on: June 10, 2021, 08:39:53 PM »
Whaaaat? You think JIS Phillips are bad?
10 of these on my coffee maker.
Where do you get a proper tool for this kind of stuff?
I got them out with my jewelers screwdriver but the blade got roughed up.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline david 750f
  • 1976 CB750F
Re: What kind of screwdriver?
« Reply #1 on: June 10, 2021, 09:03:14 PM »
Those are Tri-Wing screws, interesting that they are used on a coffee maker. Usually see them on electronic stuff. You can pick up the screwdrivers on-line or in an electronic specialty shop.
1976 CB 750F
« Reply #2 on: June 10, 2021, 09:06:42 PM »
Security screw bit set at Harbor freight used to have them in the set...not sure if they still do...
Offline david 750f
  • 1976 CB750F
« Reply #3 on: June 10, 2021, 09:13:20 PM »
Harbour Freight has them, who knew??
Thanks RAFster122s, only $7...
https://www.harborfreight.com/security-bit-set-33-pc-68459.html
1976 CB 750F
ken65
« Reply #4 on: June 10, 2021, 09:54:36 PM »
I want one now.
Offline Alan F.
« Reply #5 on: June 11, 2021, 04:43:10 AM »
+1 I think they're in the 100pc set
https://www.harborfreight.com/security-bit-set-with-case-100-pc-68457.html
« Last Edit: June 11, 2021, 04:45:08 AM by Alan F. »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: June 11, 2021, 05:29:23 AM »
I want one now.
I want to slap the guy that thought of it...  :o  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #7 on: June 11, 2021, 06:36:32 AM »
I want one now.
I say!  Plus that arsehole who invented torxes.
« Reply #8 on: June 11, 2021, 08:50:55 AM »
 One more, smack the clutch head inventor guy too. In fairness though I've ruined more phillips/jis  than any other type.
Offline rb550four
« Reply #9 on: June 11, 2021, 07:17:04 PM »
  A Tri Wing, great that's all we need. Not bad enough when there's like ten different torx heads , some can be males and others that are female,  2 kinds of Phillips  in 3 sizes each, then there's slotted in at least 5 sizes ,and then there is square drive, Then theres only like a half a million Allen heads in Metric and SAE........ I run into most of these things in a single day when taking an old house apart but I only need half as many bits putting things back together. I bought a 6 x 4 box with almost fifty different bits for my screw guns and keep it in my truck at all times, you just never know what you'll run into in one house. This is an excellent example for the pissed off thread by the way. It's especially great if any of these fasteners are damaged and nothing short of a Cat's Paw or a Sawzall will disengage one piece form another. And who would think a 3 winged screw would be an improvement over a 4 winged Phillips screw ,and if that isn't enough ,why not make the screw out of aluminum so when it strips out at least it could be a little easier to run a drill bit through it.
« Reply #10 on: June 11, 2021, 08:02:27 PM »
 I especially love the 8 point torx found on my car trailer shin. It turns out to be rare and instead of locating one it usually unscrews with a square head.
