Author Topic: Suggested timing curve setting for Dyna 2000, 1025cc  (Read 1130 times)
Offline gschuld
« on: June 11, 2021, 02:41:27 PM »
Ok, next question.  Timing curve for Dyna 2000.
Engine in question:
1025cc for road race application.
CycleX Ported head, 34/28 thin stem valves, beehive springs
New JE 72mm flat top pistons (10.5:1 compression). Great squish band area.
Carrillo rods
MotoGPworks 4/2/1 exhaust
New Keihin CR-31s with 29mm restrictor rings (AHRMA class restriction)
Dyna 2000 ignition with Dyna S pickup
Megacycle 125-75 cam
CycleX ProCut modified (backcut 2/3/4 etc) complete F Model trans
I recall #4 (of 5) being a popular choice, Paul in Australia races a 915cc l/CR-31s road race engine at the #3 setting.
Any thoughts on initial setup is welcome.
As always, thanks in advance
George
« Last Edit: June 11, 2021, 04:39:24 PM by gschuld »
Re: Suggested timing curve setting for Dyna 2000, 1025cc
« Reply #1 on: June 11, 2021, 06:00:08 PM »
George, I went with 4 simply because the info that came with it made that one seem the most logical.
Oh, and make sure the 4 pin connector coming from the pick up is snuggly connected to it's mate that goes to the brains. 2 of my pins backed out during connection and left me stranded on the side of I-25.
Dyno results??
Offline gschuld
« Reply #2 on: June 11, 2021, 07:40:13 PM »
Dyno results??
Good points.  Thx.  Dyno session is NEXT Thursday.
George
Offline Old Scrambler
« Reply #3 on: June 11, 2021, 08:12:07 PM »
Mild compression and de-stroked...................I'd choose #5 and use the retard wire in the upper rpms..........Be ready to play with the trigger setting when on the dyno ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: June 11, 2021, 11:02:19 PM »
Dyno results??
I never use that damn connector.  Hard wire it and save yourself a ton of problems.
Online PeWe
« Reply #5 on: June 12, 2021, 12:00:18 AM »
Interesting read here! ;D
The crank trigger seems to be vital.
Now I see  if full advance happen at or after 3000 rpm is no problem.
My stock advancer with cut springs delay some making low rpm cruising smooth and even.
195-200PSI tested with a cheap compr tester, all 4 cylinders to be equal. Good when comparing cams with different overlap.
Note the numbers that are useful later if something changes.
A sudden 10-25 PSI less helped me to see time for lifting the head, replacing it..
I hope I can stay away from the buy Dyna 2000 now button! ;D
Offline bear
  • Leeton in Australia
« Reply #6 on: June 17, 2021, 06:44:07 PM »
George
I would imagine he prefers the flatter curve because he's running methanol.
Offline Tracksnblades1
« Reply #7 on: June 27, 2021, 05:15:56 AM »
Engine in question:
Carrillo rods
George
What length rods did you go with..?
Do you have any Dyno time in..?
« Last Edit: June 27, 2021, 05:22:31 AM by Tracksnblades1 »
Age Quod Agis
Offline gschuld
« Reply #8 on: June 27, 2021, 12:56:36 PM »
Engine in question:
Carrillo rods
George
Dyno time turned into a disappointing debacle with no results to show for it
Standard length Carrillos.
