Author Topic: 1975F Cylinder #4 Running Hot  (Read 595 times)
Offline RogueM3
« on: June 14, 2021, 10:56:27 AM »
Similar to another thread posted, but with a different set of air-screws (round top carbs on mine). I have an especially hot #4 after fire-up yesterday and am wondering if its a bad idea to richen just the (1) air/screw for the #4 cylinder or just potentially throw in a bigger pilot jet for only 1 cylinder to correct?
I would assume its not a timing issue given #1 seems fine. Potentially could be the result of valve adjustment being out on #4?
Thanks!
Offline david 750f
  • 1976 CB750F
Re: 1975F Cylinder #4 Running Hot
« Reply #1 on: June 14, 2021, 11:06:39 AM »
Can you explain "running hot"? Are all the pipes equally warm at start up? Is the bike stock? Are the intake and carb rubbers in good shape? Checked for air leaks?
« Last Edit: June 14, 2021, 01:30:01 PM by david 750F »
1976 CB 750F
Offline newday777
« Reply #2 on: June 15, 2021, 02:41:03 AM »
Thanks!
That is a bad idea.
More likely a plugged carb port giving a lean condition.
Stu
My current rides
Prior bikes....
