Author Topic: Starter Motor Worn Out  (Read 715 times)
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« on: June 14, 2021, 08:42:50 PM »
The starter on my 750K5 is worn out.  The drive end bushing is shot ant it's causing the armature to rub against the steel part of the field coils. Does anyone know where I can get bushings for this starter?
Re: Starter Motor Worn Out
« Reply #1 on: June 14, 2021, 09:55:00 PM »
I should by a complete good looking one on eBay.
« Reply #2 on: June 15, 2021, 12:04:36 AM »
Its only brass or iolite, some body with a modelling lathe could turn you one or modify a standard one
« Reply #3 on: June 15, 2021, 06:28:41 AM »
It is an oilite bushing, sintered bronze that is porous to hold and wick oil to the surface. I replaced it with one from a starter that wasn’t worn out, I think the starter came off a Yamaha.  The starter didn’t fit the Honda, but was made by same source, and used the same bushing.
Cheers!
Offline Maltboy
« Reply #4 on: June 15, 2021, 10:08:57 AM »
Thanks for all the advice.  I tried to find a bushing that would fit, but no luck so far.  None of the Yamaha bushings listed the size, so it's hard to know which one will work.  The original bushing looks to be 13.5mm ID (shaft diameter) x 18mm OD.  I found some oilite bushings that are 12mm ID x 18mm OD but it would cost too much to have a machine shop drill one out. I could do it myself, but my drill press is a POS and I don't have a 17/32 bit (13.5mm = 17/32 inches as it turns out).  I'll probably do what PeWe said and buy a used starter.  It would've been more satisfying to fix the old one, but $ wins.
Offline 69cb750
Offline Maltboy
Offline craz1
  • CDA, Idaho
« Reply #7 on: June 17, 2021, 07:58:19 AM »
We have a local guy who rebuilds all starters. You may check your area for someone who rebuild starters and they may be able to help. We had a K2 starter and a Z1 starter rebuilt by our guy and he did a great job for $45. They are a dying breed but you never know what those shops can do for you.
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline Maltboy
« Reply #8 on: June 17, 2021, 05:55:28 PM »
A buddy sent some info for a couple of places that rebuild starters.  I'll go that route if the one I bought on Ebay is worn out too.
