Author Topic: What's a decent substitute for rubber handgrip cement ?  (Read 1997 times)
Offline grcamna2
« on: June 17, 2021, 07:21:18 PM »
I'm installing new OURY grips on my Honda and had some old spray-pump bottle cheap hairspray,it isn't holding very well.What have you used as an alternative to standard motorcycle rubber handgrip cement ?
Offline Alan F.
Re: What's a decent substitute for rubber handgrip cement ?
« Reply #1 on: June 17, 2021, 07:54:30 PM »
Aerosol hair spray, trial size, ~$1
Or dish soap, I've heard it'll work.
Make sure your bars are clean first.
« Reply #2 on: June 17, 2021, 08:02:33 PM »
well, once you have contaminated the rubber with hair spray, you are married to using something.  I generally just pop em onto perfectly clean bars and throttle tube.  They stay just fine.
« Reply #3 on: June 17, 2021, 11:33:28 PM »
i blast air under them and sort of float em on.
Offline grcamna2
« Reply #4 on: June 17, 2021, 11:36:51 PM »
These OURY grips fit a tad loose compared to the OEM old grips I removed:I'll need to use some type of rubber cement? Handgrip cement to hold them on,after thoroughly cleaning the grips off from that old pump hair spray.
« Reply #5 on: June 18, 2021, 12:15:52 AM »
maybe contact cement,you let it dry first on both surfaces a few minutes then push em on?the thing with glue is the drying/curing air get cut off till it sets?
« Reply #6 on: June 18, 2021, 06:11:05 AM »
Acetone?
« Reply #7 on: June 18, 2021, 07:14:34 AM »
Acetone?
Dont think so Per, Acetone will evaporate quickly.  Is a great cleaner though.
Grips should not slip on easily, something sounds off  - bars small or grips large??
Offline Alan F.
« Reply #8 on: June 18, 2021, 07:26:41 AM »
Throttle side might be larger bore, are you sure they're on the correct sides?
Offline carnivorous chicken
« Reply #9 on: June 18, 2021, 09:14:15 AM »
Curious -- what's wrong with standard grip glue? It comes in single use size for a buck or two, and I've never had an issue with it.
Offline grcamna2
« Reply #10 on: June 18, 2021, 10:43:17 AM »
I was just considering other ways in case grip glue wasn't available.I'm going to get some grip glue.
The left side of this grip should fit tighter(I have them on the correct sides;the throttle side does fit better) on my CB400F stock bars:I think it's this particular set of OURY grip's fit.
« Last Edit: June 18, 2021, 10:45:22 AM by grcamna2 »
« Reply #11 on: June 18, 2021, 12:05:11 PM »
yup, that is how I do it too.  You can also remove them that way and they are still re-useable.
Have always found Oury's to be top notch fit, feel, and stay-on-ability.
« Reply #12 on: June 18, 2021, 02:49:04 PM »
I was just curious -- I've heard a dozen alternatives for grip glue and I guess if it's not available where you are something else will work.
Offline grcamna2
« Reply #13 on: June 18, 2021, 02:56:05 PM »
I'm still looking for alternatives to grip glue,something commercially available someone has used(who knows what else might work?  ::) :D ) that's just as good,for the future.I don't have an air compressor,doing all this while living in a 2nd story apartment and the bike is parked on the side of my car in the lot.The left OURY did need some glue,for sure.I purchased these OURY grips on Ebay as 2 pair,they came through w/o a package so they may have been purchased originally as a Lot Sale altogether in a large bag and had been sitting?,just not sure.I've always preferred OURY grips when ever I can get them and they usually fit onto the bars and stay put with a dry-fit.
I purchased some Renthal grip glue($10 out the door) and it worked well,8hrs wait time until I can ride;it's 109 degrees out today so I think that may cut-down some of the wait time for the glue to dry.  :)
« Last Edit: June 18, 2021, 04:39:48 PM by grcamna2 »
Offline grcamna2
« Reply #14 on: June 18, 2021, 03:08:42 PM »
I also have traditionally slid new OURY grips on dry for years;I like this brand the most.
Offline grcamna2
« Reply #15 on: June 18, 2021, 04:42:50 PM »
Acetone?
I think you're right Stev-o;I believe these particular OURY grips are a bit large inside somehow,not by much though.
I don't know how but these are the first OURY grips that seem to be stretched-out inside somehow;this particular brand(OURY)seem to cancel-out the most vibration,imo.
« Last Edit: June 19, 2021, 10:00:33 PM by grcamna2 »
« Reply #16 on: June 19, 2021, 09:42:28 PM »
do they still do those doherty grips?i used to like them.
Offline grcamna2
« Reply #17 on: June 19, 2021, 10:01:26 PM »
Dave,what style are the Doherty grips:road grips for the street ?
Offline grcamna2
« Reply #18 on: June 19, 2021, 10:05:02 PM »
That Renthal grip cement that I purchased from a small shop one town over yesterday worked very well;these new grips had somehow open-up before I purchased them(heat?)on Ebay.They're on there strong now.
« Reply #19 on: June 20, 2021, 12:27:15 AM »
dirt bike grip,id use em on a road bike,nice n slim,no fussy non sense design.
https://www.ajs-shop.co.uk/acatalog/DOHERTY-HANDLE-BAR-GRIPS--PR--0700138.html
Offline aclaytonb
« Reply #20 on: June 20, 2021, 05:10:36 AM »
Never used the cement.  Goes easily on clean bars and sticks well usually.
1978 CB750K
« Reply #21 on: June 20, 2021, 05:22:00 AM »
I've heard the Oury grips are excellent, been planning to buy some.
Ouray, is an awesome Mountain town in Colorado, BTW.
My go-to grip has been the ProGrip...
https://www.cyclegear.com/parts/pro-grip-714-dual-sport-grips?sku_id=712593
Offline Alan F.
« Reply #22 on: June 20, 2021, 05:58:27 AM »
I agree with the ProGrips Stevo, last bike I put any regular & serious millage on I used ProGrips 719's
These days I'm a little older and will probably go with a set of Itallian made GT grips, they're fatter and more comfortable.
« Last Edit: June 20, 2021, 06:26:13 AM by Alan F. »
Offline grcamna2
« Reply #23 on: June 20, 2021, 07:27:43 AM »
I love the 'feel' of those Triumph-style grips;I've installed the Italian brand of them before.
Offline grcamna2
« Reply #24 on: June 20, 2021, 07:31:20 AM »
Dave,they look fat enough to help with vibration.I've looked for the Bar Snake for a long time now:have they entirely discontinued it??
