Author Topic: LED turn signal issues 74 cb550  (Read 985 times)
Offline jamiebridge
« on: June 19, 2021, 12:22:10 PM »
Hello all, first post.
I have replaced my oem indicators with some motogadget pins.
I have wired them up exactly how the old units came off but im not getting any light from them at all.
I know i need a new relay and a diode to get them working properly, but i thought plugging them directly as the stock ones were i would at least get a solid light or something?
The old ones that came off didnt have a ground wire, im assuming that the ground was the fork shroud. So i plugged the new black grounds into the free ground plug in the headlight. Is there anything i am missing here? All other electrics including rear turn signals are still working fine.
Thanks
Offline calj737
  • Moderator
  • I refuse...
Re: LED turn signal issues 74 cb550
« Reply #1 on: June 19, 2021, 01:42:51 PM »
You only need a diode if both light up when one side is selected but both bulbs ignite.
If your headlight bucket is fiberglass, choose a different ground. Maybe use the horn ground location? You don’t disclose where exactly you installed the new Pins, so it’s a bit more difficult to visualize a solution.
Offline jamiebridge
« Reply #2 on: June 20, 2021, 01:50:09 AM »
You were spot on. It was a ground issue. Got them both working, put everything back together and now nothing works haha. I think i may have drained the battery as i get the neutral light for about a second and then it dies out. Thanks for your help
Offline jamiebridge
« Reply #3 on: June 20, 2021, 02:38:50 AM »
Correction on post above.
Came back to it an hour later with a multimeter, battery measured fine.
Tried indicators. Both perfect. Switched it off, turned it back on… nothing working.
So strange!
Online newday777
« Reply #4 on: June 20, 2021, 03:58:40 AM »
So strange!
Load test the battery. You might have an internal short in the battery.
Stu
My current rides
Prior bikes....
