Author Topic: MrFry's CB750 Cafe Project Thread  (Read 38476 times)
Offline MrFry
    • T-Fry.com <--Under Construction
Re: MrFry's CB750 Cafe Project Thread
« Reply #125 on: March 25, 2007, 06:16:41 PM »
I could be wrong but I think the intake and exhaust tappets are supposed to be adjusted to .002" and .003".  You may want to double check.  That's what it says in the specifications section of this site.
...wow, perhaps i should be checked for dyslexia...
you are right, i just checked my manual again.
back to the garage
Offline MrFry
« Reply #126 on: March 25, 2007, 06:59:12 PM »
...now that sounds better!
no more carb-backfire's either
 ;D
soooo much easier to do with the thinner feeler gauge
Offline mrblasty
  • Expertly
« Reply #127 on: March 25, 2007, 10:46:02 PM »
The honda shop down the street from my house has individual feeler gauge blades for this very function,
I think motion pro makes them
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline doug_id
    • My Cafe 550 Project Gallery
« Reply #128 on: March 26, 2007, 05:01:43 AM »
Yeah, I just bought a pair.....much easier to use than the hand bent ones I was using.  8)
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline MrFry
« Reply #129 on: March 26, 2007, 08:06:40 AM »
hmm, once i used the correct gauge, it really wasn't to hard.
in my case (since i knew they were all too loose), i set #1cylinder to TDC, loosen lock nut and slide feeler gauge in. Tighten Adjuster till the gauge won't slide anymore, then back off a hair till the gauge moves, then double check, and tighten the nut while holding a screwdriver on the adjuster (so it doesn't move). Double check with feeler gauge and move on to the exhaust side of #1 cylinder.
     1 2 3 4
IN: O X O X
EX: O O X X
i'm trying to remember that off the top of my head (and i just woke up). With the #1 Cylinder at TDC, you should be able to check the intake and exhaust of #1, Exhaust on #2, and intake on #3. With the #4 cylinder at TDC (rotate the crank 360 degrees), you can check #4 intake and exhaust, #3 exhaust, and #2 intake.
Offline MrFry
« Reply #130 on: March 26, 2007, 08:11:03 AM »
here are some vids comparing the different exhausts...
Uncored Kerker 4-1 Exhaust
http://www.youtube.com/watch?v=fCnHRTWBCXQ
cored with Butt-Plug
http://www.youtube.com/watch?v=4o7B_jd2Qdk
Without Butt-Plug  >:D
http://www.youtube.com/watch?v=3ZOnIbKTsqs
i think i'm going to get the competition 2" exhaust from these guys
http://www.dynoman.net/exhaust/baffles.html#dbae
uncored the exhaust was pretty quiet, but right now it's too loud. I personally don't mind it, but i have a feeling the neighbors wouldn't be to happy when i warm it up in the morning
Offline MrFry
« Reply #131 on: March 26, 2007, 02:39:54 PM »
new question.
How do you adjust the cam-chain tensioner?
i couldn't find a detailed procedure.
i know these are noob questions, but i've never had a CB750 before, and things are done a little.... different, than what i am used to.
« Reply #132 on: March 26, 2007, 02:50:39 PM »
A bent feeler gauge will go in there.
You've got to make sure they are open.
You can wiggle them with your fingers.
--won't budge if they're not open--also gauge won't go in there.
i should be checking these with the timing at the "T" mark yes?
i made this out of a feeler gauge, and i can only use it on the first and last cylinder. 2 & 3 are blocked by the frame.
Looks more like a tyre leaver ;D ;D ;D ;D ;D...no wonder it was making a noise ::) ::) ::) ::)
Sam ;)
Offline MrFry
« Reply #133 on: March 26, 2007, 03:05:33 PM »
Sam ;)
 :'( yeah, i thought .020 seemed a bit excessive but i could have sworn i checked the manual twice!
Offline MrFry
« Reply #134 on: March 26, 2007, 07:40:29 PM »
decided to try and dremel a banjo bolt to fit the caliper
turns out, it works good!
i screwed a steel nut on the bolt before i started cutting it to clean up the threads after i was done.
so i go to install my brand-spanking-new line and i can't get any fluid to come out...
open the master, theirs fluid in there.
take the line off - the master isn't pumping anything. Looks like it could use a rebuild
now for the questions
1.) How do you adjust the cam chain tensioner?
   do you just undo the locking bolt and it springs into place cause mine doesn't seem to do anything.
2.) what is a good aftermarket Master Cylinder? or perhaps one of another bike that will fit (and is better).
« Last Edit: March 27, 2007, 12:11:18 PM by MrFry »
Offline doug_id
« Reply #135 on: March 26, 2007, 08:08:15 PM »
Lots of good used modern master cylinders on e-bay.   Think mine came of some mid 90's model.
« Last Edit: March 27, 2007, 06:18:42 AM by doug_id »
02 Concours
78 CB550
Offline MrFry
« Reply #136 on: March 26, 2007, 10:08:46 PM »
anybody use one of these?
http://www.shindypro.com/newpro/
Offline mrblasty
  • Expertly
« Reply #137 on: March 26, 2007, 11:10:45 PM »
Looks expensive.
1973 Honda CB 750
1975 GL 1000
Offline MrFry
« Reply #138 on: March 27, 2007, 08:06:20 AM »
yeah, that's what i'm thinking. Couldn't find a price though
tmht
« Reply #139 on: March 27, 2007, 08:36:39 AM »
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=&store=Main&catId=410&productId=p193153&leafCatId=41006&mmyId=
$146.99 from Dennis Kirk. Could be worse, could be much better.
Offline MrFry
« Reply #140 on: March 27, 2007, 06:48:49 PM »
UPDATE
Just got my new (used) supersport tank today.
It's not in horrid condition but it isn't pretty.
it has 2 decent dings in the side with creases, so once again i am out chasing down someone to take them out.
the inside has slight rust and was shipped with gas!
...it reeks, and wont come out of my skin - my experience tells me it's old.. and i smell
the idea is to completely strip this one, polish the sides, and paint the top strip black.
but now i'm thinking of sand blasting the tops strip - just to make it stand out.
dents outlined
sitting on bike
this is going to look waaaaay better than it was with the old tank(s)
Offline MrFry
« Reply #141 on: April 02, 2007, 07:11:20 PM »
Sorry the updates have slowed down a bit - i've been super busy trying to find a job, going out of town, etc etc.
right now i'm waiting for a lever to come in for my new (old) master cylinder off a VFR 800
decided to start prepping the frame to make the seat.
i used aluminum (duct) tape to cover the frame, and i cut out some cardboard for the rear section. I need to grind off the brackets where the tape is missing.
I plan on laying the fiberglass directly to the tape for the seat base.
after that is cured i am going to cover the pan in the tape and put expandable foam on the rear section to form the 'hump'.
once i am happy with the form i will cover it in tape and lay fiberglass directly on top of that.
once that has cured i will remove that piece of fiberglass and start on the upholstry pan - same process.
the idea is once the 3 pieces are made the 'hump' will be hinged and lockable to the seat base for storage.
Offline Roach Carver
« Reply #142 on: April 02, 2007, 07:40:04 PM »
Is there going to be a flat area of fiberglass behind the frame support? If so are you worried about tire clearance issues?
Offline MrFry
« Reply #143 on: April 02, 2007, 09:55:00 PM »
Drat! didn't think of that
guess i better do some measuring
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #144 on: April 03, 2007, 09:10:40 AM »
Dude, just pull one off a newer bike.  Hella cheaper.  I got all my controls, clutch lever and master cylinder off of a 05-06 GSXR for $15-ish bucks off e-bay.  They even came with clip-ons that I turned around and sold for $10.  My brakes were great, no problems.
1969 CB750K - Wrecked
1978 CB750K - Sold
1992 GS500 Streetfighter - Sold
1975 CB750F - Sold (sniff, sniff)
1994 VFR750F - Sold
1990 GSXR 750 - Sold
1999 CBR1100XX - Sold
2000 Triumph Legend TT - Bike of the week for me?
1992 Mustang - Paxton powered (12.02@115mph on street tires) and For Sal
Offline MrFry
« Reply #145 on: April 03, 2007, 09:13:08 AM »
well shoot - just went out and played with the bike a little.
off the centerstand while pressing on the rear there isn't much clearance between the tire and my "shelf". and i'm sure i will get more load while riding over bumps or through dips.
looks like i'll have to make it a two-piece tail section. So, no storage.
oh well, makes it that much easier i suppose.
Offline MrFry
« Reply #146 on: April 03, 2007, 09:13:57 AM »
yeah, i'm waiting for a lever to come in for a 1999 honda VFR 800 master cylinder.
just gotta figure out a mirror mount after that - but that shouldn't be to hard.
Offline MrFry
« Reply #147 on: April 03, 2007, 07:22:41 PM »
started on the seat...
just going to do a 1-piece seat seeing as i don't have enough clearance to have any sort of storage space.
2 cans of expandable foam:
i'm going to let it sit overnight and start shaping it tomorrow
word of advice - don't get this stuff on your skin (or anything else you treasure) it is NASTY!
Offline paxtonpony
  • Up the Irons!
    • My Pics
« Reply #148 on: April 04, 2007, 07:42:16 AM »
Fly-n-cycle has a mount for mirrors but I'd just run bar end mirrors if I were you.
1978 CB750K - Sold
1994 VFR750F - Sold
Offline MrFry
« Reply #149 on: April 04, 2007, 08:04:10 AM »
yeah i have a set of small CRG bar-ends that came with my Monster, but i like the mirrors i have on there now.
I will use those as a last resort. i'm thinking if i can find a brake master cylinder with the mirror hole on the mount i'd be set.
