Author Topic: Nifty tool for sticky Carb slides..  (Read 730 times)
« on: June 23, 2021, 06:25:12 PM »
 Stroke of luck that I spied it in my toolbox, not sure what i used it for in the fjist place.
 Anyway carbs that sat with sticky slide..VERY VERY  easy to damage carbs , getting the slide to move.. not to mention on an accelerator pump jet you can bend it.
 Nick your  slide , makena mark in it, then pull it out anyway, wrecks the body.. this is so simple anyone can make it
 I used a twisting motion., its made out if the brace that goes between  wooden chair legs.. back side if the tip is rounded.
« Last Edit: June 23, 2021, 06:29:27 PM by 754 »
Offline dazemc
Re: Nifty tool for sticky Carb slides..
« Reply #1 on: June 23, 2021, 07:47:14 PM »
Any tips on getting a stripped screw out of the slider assembly? 🤦
1971 CB500
« Reply #2 on: June 23, 2021, 08:28:56 PM »
You mean the scrws going ito the slide  on the lifter arm ? DRILL the head off.,
