Author Topic: Quick Head Gasket Question  (Read 623 times)
Offline jakec
« on: June 24, 2021, 10:12:49 AM »
Two quick Q's...
1. The head gasket bows in the middle when installed. It's caused by the two dowels at the front of the cylinder. If I made the holes in the gasket slightly larger, it would sit flat. My question is if I should bother modifying the gasket or use as is?
2. My dirty finger got some oil or grime on the gasket which I tried to wipe off with acetone, but it smeared. The gasket is dry and "clean" but it's stained now. Just wondering if this would be a problem.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline 69cb750
Re: Quick Head Gasket Question
« Reply #1 on: June 24, 2021, 11:30:19 AM »
Does gasket bow cause it is bowed or does gasket bow cause of the pins ?
Press gasket flat between dowels with piece of wood and see what happens (or report here).
Offline jakec
« Reply #2 on: June 24, 2021, 11:45:21 AM »
It is brand new and was flat when I pulled it out of the package. If you push it flat between the dowels it will just push the wavy area someplace else.
If I used a dremel and shaved off 1mm in the red highlighted area it would sit flat. (actually I highlighted the wrong side of the gasket but you get the idea)
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline 69cb750
« Reply #3 on: June 24, 2021, 12:48:15 PM »
I would modify gasket.
Offline jakec
« Reply #4 on: June 24, 2021, 12:54:19 PM »
Sanding wheel on dremel ok? It's pretty thick so I don't think I can make a clean cut with an exacto knife given the shape of the cut I need to make. Also no concern about the grease stain?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline 69cb750
« Reply #5 on: June 24, 2021, 01:39:51 PM »
I have no concern about the grease stains, I've had lots of them.
I recently sanded my shop floor with #220 wet dry, looks better now.
