Author Topic: do i have to take the frt wheel off to chance brake pads cb 400f?  (Read 494 times)
Offline Redline it
  • thread killer
i can't remember a year or 2 if i did. they look so easy to take off. i have no idea how many times i've changed them in the last 40yrs. a few times at least. can't i just take the caliper bolts out and the line off? thanks.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: do i have to take the frt wheel off to chance brake pads cb 400f?
« Reply #1 on: June 24, 2021, 02:33:41 PM »
On my K3 750 I can just remove the caliper.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Redline it
  • thread killer
« Reply #2 on: June 24, 2021, 02:35:42 PM »
cool, i think i'm gonna try that. thanks alot.
Offline robvangulik
  • Honda Fourever
« Reply #3 on: June 24, 2021, 03:13:31 PM »
Just take the bolts out and let the line be, it's as easy as you think.
Offline Bodi
« Reply #4 on: June 25, 2021, 04:17:01 AM »
To just replace the pads, split the caliper and swap them in. With really worn pads be careful the master reservoir doesn't overflow when the piston is pushed back in.
I like to pop out and inspect the piston when I'm in there. Usually with the brake hose still attached.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #5 on: June 25, 2021, 08:28:03 AM »
Be very careful the new pucks fit smoothly in the bores, one of mine had a little hangup that froze it. I had to remove the caliper and dress it to get it to stop sticking.
1973 CB 750 K3
