Author Topic: Exhaust Ebay  (Read 833 times)
Offline kamperman69
Exhaust Ebay
« on: June 27, 2021, 08:46:35 AM »
 Was Wondering there is  a exhaust on EBay says its for a 1981 will it fit a 1978 750K model?
Thank you
Re: Exhaust Ebay
« Reply #1 on: June 27, 2021, 08:50:15 AM »
Nope
Offline kamperman69
Re: Exhaust Ebay
« Reply #2 on: June 27, 2021, 09:02:47 AM »
Numbers are HM425 Sankei 2043??
Offline Alan F.
Re: Exhaust Ebay
« Reply #3 on: June 27, 2021, 09:05:01 AM »
No, the 81 is a different bike. In the States we had SOHC CB750 until 1978. In 1979 we got the DOHC bikes, DOHC pipes will not fit SOHC bikes.
I recommend:
https://delkevic.co.uk/s/Honda/CB750K/1977
« Last Edit: June 27, 2021, 09:09:30 AM by Alan F. »
Offline kamperman69
Re: Exhaust Ebay
« Reply #4 on: June 27, 2021, 09:10:19 AM »
OK thanks for the quick reply.
Re: Exhaust Ebay
« Reply #5 on: June 27, 2021, 11:20:50 AM »
I have seen a CB750 SOCH with Vance & Hines 4-1 for that later twin cam 750 if I understood correctly.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Exhaust Ebay
« Reply #6 on: June 27, 2021, 11:32:21 AM »
I’ve heard the same, but never tried it.
Offline Tim2005
Re: Exhaust Ebay
« Reply #7 on: June 27, 2021, 11:34:13 AM »
It will fit the cylinder head ok,  but as the later engines have a large sump there will be a gap under the motor /
above the exhaust.
Offline Alan F.
Re: Exhaust Ebay
« Reply #8 on: June 27, 2021, 01:13:33 PM »
Yes the DOHC engines are a few inches taller, so there will be a gap between the pipe and the bottom of the engine. If you're a talented welder you can shorten the headpipes to make it fit. It's been done here on the forums a few times.
