Dyna-S seems to be OK nowadays.
Even my K2 got it last summer when it started to run really bad. Point 2-3 was not possible to adjust. Probably damaged point.(TEC).
I gave up, checked my close bike shop on internet, yes in stock. Called them and doublechecked stock status. He went to the shelves and picked the last one for me that arrived 5 minutes later.
It took max 5 minutes to adjust after 15 minutes install. Plate in middle position, started engine and adjusted with stroboscope. Both 1,4 and 2,3 OK.
Bike already had an extra 12V connection ready to connect.
Dynas instruction more like a fault tracing guide.
I use cut advancer springs so it work fine to adjust at 1200rpm idle. Full advance will kick in at around 2600-2700 rpm. Work fine on stock engine and more modified with much hotter cam.
Z1-900 might not have issue with sloppy adv springs letting advance increase too early and quick as CB750?
A pure stocker bike have a reason to use the old original ignition though.
