Author Topic: Maui Z1 1973  (Read 65457 times)
Offline craz1
  • CDA, Idaho
Re: Maui Z1 1973
« Reply #775 on: May 20, 2022, 04:43:56 PM »
Photo's?
74 CB550,73 Z1900, 74 Z1900, 75 Z1900,
72 XS2650, 73 RD350, 2013 FJR1300, 84 XJ550 YAM
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #776 on: May 21, 2022, 08:01:15 AM »
I went through blue checking one set of bearing shells at a time with the opposite end of the cam supported by a lower shell to keep it straight. I used a new bearing set for the check.
I found two shell sets pinching at the split on the exhaust cam which was also accompanied by the cam tightening up when assembled. I looked carefully at the area where the split is and found that if I lightly relieved the corners the pinch went away. Now that I know this I can easily tell because those shells needed a little extra push to get them to seat in the saddles.
The intake cam had one such pinched bearing.
How did this condition develop? Hard to say. The obvious thing is that the caps may not be original to the head but I don't think so, they match up nicely. One possible answer might be a difference between cam bearing shells available now vs what was available when it was built.
The cams turn freely now when all bearings are installed.
Now I need to get a new set of cams and bearings to continue.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline craz1
  • CDA, Idaho
Re: Maui Z1 1973
« Reply #777 on: May 21, 2022, 09:04:13 AM »
Sounds like your making progress. But before you put the valves back in check with plstigage to see if you have a consistent reading across the surface of the cam journal. Try not to touch the surfaces of the new bearings when installing Use gloves.
One more thing I just thought of. make Sure the locating pins are not to long and you have space above the pins. They should be ok but doesn't hurt to check.
« Last Edit: May 21, 2022, 09:31:44 AM by craz1 »
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #778 on: May 21, 2022, 02:24:23 PM »
All good suggestions
Here’s a more thorough recap.
Went through all the bearing locations one at a time with the other end supported by a lower half shell. I learned that three locations were pinching the split. Two on intake, one on exhaust. I lightly eased the very edges of the split on the caps and head, just like removing an edge burr. This fixed the problem, cams move easily now when fully assembled.
this begs the question, why now?
I did not save the old bearing shells so I can’t compare them but the only thing that changed was the bearing shells. I’m going to have to settle on a minor difference in the newer bearing parts and perhaps an unfortunate stack up of manufacturing tolerances, it’s all I can think of. It took so little to fix it just boggles the mind. The bearings are from Z1 enterprises and I think I was just unlucky and inexperienced with the Z1.
the other option is that the caps are not original to the head. This would be tempting to latch on to but the motor ran well when I straightened out the carbs.
I chalk this up to a bad rookie mistake. I never thought to check the sides of the fit, just the vertical clearance with plastigauge. Also, I now know that if the shell doesn’t settle in to the saddle easily there is a problem. If it wants to snap in it’s likely going to pinch at the split. So the real test is to put the bearings and cams in with no valves installed, if it is difficult to turn, there is a problem.
Looking for a set of cams, stock if possible, or at least close to stock. I don’t want a hot rod engine.
1973 CB 750 K3
Offline craz1
  • CDA, Idaho
Re: Maui Z1 1973
« Reply #779 on: May 21, 2022, 03:02:19 PM »
Cams are easy to get on eBay. I wouldn't worry if they a hollow or not as the early Z1 bikes were. Any cam from 73-76 will work. If possible have them give you the lobe and journal measurements. I never had a bad cam as far as being worn except for one 74 I bought where he spit out a shim and they tried to re-grind the cam. If you cant come up with anything I do have several sets.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #780 on: May 22, 2022, 07:49:33 AM »
Thank you, I may take you up.
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #781 on: May 23, 2022, 07:58:05 AM »
I put the engine lower back in the frame, ordering some gaskets and working on getting cams.
Lots to do
1973 CB 750 K3
Re: Maui Z1 1973
« Reply #782 on: May 23, 2022, 09:44:39 PM »
Glad you figured out what was going on...it is an odd issue to encounter.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #783 on: May 24, 2022, 08:01:04 AM »
Still looking for a set of cams. No confirmed hits yet, I may have found something at Johnny's Vintage, have to check.
1973 CB 750 K3
Re: Maui Z1 1973
« Reply #784 on: May 24, 2022, 01:31:50 PM »
I must check Johnny’s website, I need a ‘73 Z1 head for the engine I plan to build this winter. ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #785 on: May 24, 2022, 02:14:46 PM »
I’ve bought from them several times, good outfit.
1973 CB 750 K3
Re: Maui Z1 1973
« Reply #786 on: May 24, 2022, 02:30:41 PM »
Thanks Steve, I like his videos too, they do good work. ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #787 on: May 25, 2022, 07:51:26 AM »
I just got a tip from the KZ Rider forum. He said he always runs a 12mm drill down the stud holes in the cylinder block to clear any potential casting flash. I'm going to check this out just to be sure. The rear outside two are oil passages.
1973 CB 750 K3
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #788 on: May 26, 2022, 07:49:53 AM »
I contacted a shop in Tacoma that fixes camshafts to see if they can clean up my hollow cams. I just need the journals worked on, the lobes are ok.
1973 CB 750 K3
Offline grcamna2
Re: Maui Z1 1973
« Reply #789 on: May 26, 2022, 12:36:43 PM »
The shop you contacted,what's their name?
There's a camshaft place called Delta which I would not recommend,I hope that's not the one you contacted.
75' CB400F/'bunch o' parts'
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #790 on: May 26, 2022, 01:54:04 PM »
Delta
Why do you not care for them, he seemed to know what he is doing, John is his name.
Curious
He’s going to polish the journals.
1973 CB 750 K3
Offline grcamna2
Re: Maui Z1 1973
« Reply #791 on: May 26, 2022, 03:16:59 PM »
Delta
Curious
I'm a member of the Honda twins forums and they had sent work to them for CB350 twins.
There are a number of jobs that were contracted where Delta(they had a change of ownership a couple years ago)hard-welded rocker arms and camshafts and they didn't match the finished spec when compared to the OEM parts.I have heard from some folks on these issues that Delta isn't really dependable. Steve,I'm just saying what I heard.
They may do a good job on polishing your cams though,just not certain.
I know of a man who can steer you right on this on that forum who actually lists his phone number at the bottom/signature of each post.His name is Jim O'Brian and if you like I can send you a PM with his contact #.
Jim will give you the 'straight scoop' on it.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #792 on: May 26, 2022, 07:09:19 PM »
Sure thing, thank you
1973 CB 750 K3
Offline grcamna2
Re: Maui Z1 1973
« Reply #793 on: May 26, 2022, 07:48:53 PM »
Ok,a PM will be on it's way.
He's putting in a good amount of time monitoring the VHT site so should answer directly.
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #794 on: June 14, 2022, 07:51:42 AM »
I think my tank and body stuff are done, making arrangements to go over to Oahu and pick them up.
Still waiting to hear about cams.
Making a little progress
1973 CB 750 K3
Offline Alan F.
Re: Maui Z1 1973
« Reply #795 on: June 14, 2022, 12:30:31 PM »
Great news!
Edit: I'm with Terry, before & after pics would be cool.
« Last Edit: June 14, 2022, 02:00:44 PM by Alan F. »
Re: Maui Z1 1973
« Reply #796 on: June 14, 2022, 01:15:29 PM »
Post some pics of those shiny painted parts Steve, I’m keen to see that tank brought back from the dead! ;D
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Maui Z1 1973
« Reply #797 on: June 14, 2022, 02:22:58 PM »
Will do!
1973 CB 750 K3
Offline grcamna2
Re: Maui Z1 1973
« Reply #798 on: June 14, 2022, 04:43:06 PM »
+1  ;)
Re: Maui Z1 1973
« Reply #799 on: June 15, 2022, 05:23:56 AM »
That very tank is very special if it is the original tank of this very special model and year.
I also look forward to see photos. ;)
