Author Topic: CB750A Hondamatic sharp metallic clinking and clanking  (Read 13648 times)
Offline jukku
  • Happy with my Hondamatic
« on: July 12, 2021, 09:43:02 AM »
Sharp metallic clinking and clanking when in gear but unloaded.
Spare parts list page E-18 item 15 shaft stator (fork)
Spare parts list page E-18 item 10 shaft input (broken damper springs)
Spare parts list page E-14 item 17 regulator valve (operated by item 15)
Spare parts list page E-15 item   1 crank case (upper part)( steel pin limits the fork movement)
When the springs are broken the system is, in gear but unloaded, not in balance and the fork starts smashing the pin back and forth. Thats is the sharp metallic clinking and clanking.
Today, after more than 2 years of clinking and clanking, I opened the gear box to find out the source of the noice.
I dont know if the regulator valve completely ok. I do not think it is dameged.
Hope you have any help of the pics.
Start tomorrow to put the gearbox together and perhaps put in a 836ccm 9:1 bore kit, F2 cam shaft and K7 carbs.
If the weather is not too hot.
Offline jukku
Re: CB750A Hondamatic sharp metallic clinking and clanking
« Reply #1 on: July 20, 2021, 12:01:31 PM »
3 of 4 springs broken.
« Reply #2 on: July 20, 2021, 02:49:56 PM »
Are you having any luck finding parts?
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #3 on: July 20, 2021, 03:09:26 PM »
Springs, clutch discs and fibers are available
« Reply #4 on: August 11, 2021, 12:54:10 PM »
Have you made any progress?
« Reply #5 on: September 04, 2021, 10:18:58 AM »
 The reason I ask is I have the bottom half of a cb750A engine. I'm considering opening it up to see what's inside or junking it.
  • Gusto mo titi ko?
    • project
« Reply #6 on: September 04, 2021, 11:48:05 AM »
Don I have sourced the parts I posted above. I got part numbers from kmb in a post here on the board. I’m pretty sure I got the clutch parts from raybestos, the springs might have come from keith.. I will try and find out for sure who I got them from.
I am just looking for someone that can increase stall speed on the TC before anything else. I contacted Britain parts, but neither of us followed up.
« Last Edit: September 04, 2021, 12:19:35 PM by Medyo Bastos »
  • Gusto mo titi ko?
    • project
« Reply #7 on: September 04, 2021, 12:18:36 PM »
keith and mike both chimed in L@@kie here->
Clutch plates for 1977 CB750A Hondamatic
 https://r.tapatalk.com/shareLink/topic?share_fid=13548&share_tid=163702&url=http%3A%2F%2Fforums%2Esohc4%2Enet%2Findex%2Ephp%3Ftopic%3D163702&share_type=t&link_source=app
« Reply #8 on: September 04, 2021, 03:48:40 PM »
Tapatalk link doesn't work for me...
Offline kmb69
« Reply #9 on: September 05, 2021, 08:50:27 AM »
Springs came from JTMarks, RIP, off eBay. He just recently died. Not sure where he was getting them.
Pretty sure he was selling mold release springs from somewhere - not OEM Honda stuff. They worked!
Brittain's website appears to no longer be up and the last post on their FB page was June 23, 2018. Huh?
Not to mention, pictures I saw of their CB750A convertor mod looked like hammered $hit!
Need to find a new convertor expert IMHO.
Offline kmb69
« Reply #11 on: September 05, 2021, 08:06:08 PM »
McMaster-Carr lists them as "die springs". Pick a flavor, plug in the length, OD, and wire width and see what they have to offer..
https://www.mcmaster.com/die-springs/
« Reply #12 on: September 05, 2021, 10:36:14 PM »
If you have a set, then taking a set of good measurements might help any future or current cb750A owners order replacements from McMaster Carr.
« Reply #13 on: September 07, 2021, 10:43:05 AM »
 That is awesome. Good work and appreciation to the helpers.
« Reply #14 on: September 08, 2021, 02:12:14 PM »
   I was told Coan converters has some experience with the 750A's. I read that they can't change the fin angle but can increase the gap between the stator and rotor.
  Worth a call, they built the ones in my dragster, I have one that was raced for 7 years, rebuilt at 2 and then raced for the next 5. Still works but I replaced it because we were chasing points and didn't want to chance it. The one in it now has 3 seasons but short ones.
« Reply #15 on: September 08, 2021, 04:58:15 PM »
Yes....we've (a few people) have seen that (regarding stator fins). Personally I wasn't that impressed as the work was done by hand....it could be done on a rotary table and mill at the least.....CNC at the best. I've taken a few auto engines apart at this point and those square springs have been shattered in every engine (stock applications too). A #$%* design IMO that could have been avoided.
« Reply #16 on: September 08, 2021, 07:57:32 PM »
Where inside an auto engine have you seen those springs? I've seen them used as dampers in clutch discs, but never inside an engine?
  • Gusto mo titi ko?
    • project
« Reply #17 on: September 08, 2021, 09:13:21 PM »
« Reply #18 on: September 08, 2021, 09:29:17 PM »
Brain fart :-[ :-[; I took it to mean automobile engine. ::)
« Reply #19 on: September 09, 2021, 06:24:39 PM »
 I had a look at the innards from an A.  It's not nearly as intimidating as I expected.
  It makes me wonder if it is the inspiration for the modern dual clutch transmissions. Mine was silicone'd on the covers, so someone was in there ahead of me, possibly why it was abandoned. The top end however, was very nice so the goo didn't plug the oil jets. Probably didn't work after the intrusion.
  • Gusto mo titi ko?
    • project
« Reply #20 on: September 09, 2021, 06:31:40 PM »
fyi, I contacted coan via email and they replied, but no way no how… BUT, got a second email from a fella named Todd stating:  “I actually talked to the boss and did some leveraging since I’m a motorcycle guy myself and we can look at it to see if we can do anything with it, however we cannot make a guarantee that we can change the stall until we get it here and take a look at it.”
I will be sending my tc to them, and will update this post in case anyone else is interested!
« Last Edit: September 21, 2021, 07:12:45 PM by Medyo Bastos »
« Reply #21 on: September 09, 2021, 07:50:22 PM »
 Cool, they have always treated me well. The first powerglide converter I sent in was cut open and inspected, it was a disaster inside. He shipped it back for $7 so I could see it for myself. The guy said it looked like a little bulldozer drove around inside, he was correct.
« Reply #22 on: September 09, 2021, 08:10:34 PM »
 I noticed Honda lists end plates in different thicknesses, I wonder if that is to adjust the clutch / plate stack height?  I've seen that in clutch type positraction differentials.
Offline kmb69
« Reply #23 on: September 10, 2021, 06:20:43 AM »
fyi, I contacted coan via email and they replied, but said no way no how… BUT, got a send email stating:  I actually talked to the boss and did some leveraging since I’m a motorcycle guy myself and we can look at it to see if we can do anything with it, however we cannot make a guarantee that we can change the stall until we get it here and take a look at it.
Definitely interested!
« Reply #24 on: September 12, 2021, 09:18:24 PM »
  Sorry for the thread hijack,
Just a Coan story, I asked them to build a tighter converter for our drag car and they got the specs out on what I already had. The converter guy guessed the name of my Dragster's engine builder based on where I was located and the torque/horsepower curve. The motor was built by a Super Stock guy and he said my existing converter is exactly the one he would spec for a Super Stock door car.
 Moral of the story, the new one was too tight and didn't work as well as their first try. It would carry the front wheels 60'.
